Fuel pressure regulator for 954RR - Honda Motorcycles - FireBlades.org
 3Likes
  • 1 Post By MrPickwick
  • 2 Post By 954Kevin
post #1 of 5 Old 05-31-2018, 12:15 PM Thread Starter
Hey guys, was having some issues with my 954RR being sluggish (2003 Honda CBR 954RR 8k miles) So I replaced the plugs, changed oil, new air filter, fuel system clean etc... Fuel pump was also replaced late last season.
Read online that these bikes often have FPR Issues. So after I did all of the listed above I took the vacuum hose off my FPR and sure enough when the fuel pump primed the bike, Gas came pouring out of where the vaccum hose normally attaches to the FPR.
So I'm guessing that means the diaphragm/ FPR is totally shot correct? I can post a video if need be. If this is the case:
Where is the best (cheapest/fastest) place to order a replacement?
Does anyone know the honda part number for the FPR? I've found 16740-MCJ-013
Are there other FPR's that are swap in replacements for this one?
I have searched a bit but all the information I've found is very ambiguous.
Thank you for your time and any help.
Thread I found for reference: https://cbrforum.com/forum/cbr-954rr...or-mod-151648/
Boosted is offline
post #2 of 5 Old 05-31-2018, 12:47 PM
Quoted: 487 Post(s)
Re: Fuel pressure regulator for 954RR
Maybe have a look at Partzilla
https://www.partzilla.com/search?q=16740MCJ013
BigdaddyPaz likes this.
MrPickwick is offline
post #3 of 5 Old 06-01-2018, 1:58 AM
Quoted: 691 Post(s)
Reputation Power: 102
I think someone on here with a 954 replaced his with one from a VTX. He said the vacuum nipple was rotated to where the 954 one is, but worked nonetheless. A search should produce it here. I guess the VTX one was cheaper at the time he replaced it. Worth a look I guess.
IanDoohan is offline
post #4 of 5 Old 06-03-2018, 8:56 PM
Quoted: 47 Post(s)
Reputation Power: 47
thats what i was gonna suggest, but i couldnt remember what model bike the fpr came from that he swapped in. i was thinking it was a 1100xx.
i think id avoid all the hassle of the ebay universal fpr personally. seems like the 954's oem fpr use to be more expensive, like over 100$. i could be wrong, but for 70$, i think id just buy the oem unit meant for the 954 n call it a day.
IanDoohan and BigdaddyPaz like this.
954Kevin is offline
post #5 of 5 Old 07-11-2018, 4:29 PM
Quoted: 28 Post(s)
iirc 929 and 945 are the same part 16740-MCJ-013 but doesn't seem to cross reference to any other models - the 929 had another which was discontinued, end 003, presumably due to failure(?). CBR6's seem to have a different one.
machinehead is offline
