954 rattle - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 05-14-2019, 5:44 PM Thread Starter
954 rattle
Hello guys!
I have a 2002 954rr which I,ve had for a bit over a year now. The cam chain has rattled when the engine is cold ever since i bought the bike, but just before winter it also started making valve noise.
So I took the bike apart during winter, adjusted the valve clearances and swapped out the old CCT with a new one (OEM). But ever since i swapped out the CCT the engine rattles like crazy when cold then calms down when it hits approx 50 degrees C. I read everywhere that this is normal for the 54s' ,but the bike sounds it is going to fall apart when cold and I can't help but worry about the engine breaking down. The CCT is original and brand new.
Can someone please explain what the reason for this may be, and if possible how to resolve this issue?
Dealia is offline
post #2 of 6 Old 05-15-2019, 2:23 AM
nigelrb's Avatar
Quoted: 60 Post(s)
Reputation Power: 3
Send a message via Skype™ to nigelrb
Re: 954 rattle
Not wishing to insult your mechanical skills, but might it be possible you've reinstalled with the cam one tooth out?
I wonder this because when you say that just before winter it started making valve noise, that suggests the loose chain might have jumped at that time. If you've replaced it in that exact position, that will explain the continued noise.
2018 CBR1000RR SP2 / 2011 CBR1000RR / 2004 CBR1000RR / 2003 CBR954RR / 2001 CBR929RR (Erion Racing Edition)
1985 Honda VF1000R / 1985 Honda NS400R
2007 MV F4 1000R
nigelrb is offline
post #3 of 6 Old 05-15-2019, 2:54 AM Thread Starter
No. I thought that might be the case, so I stripped down everything again to check. Both marks on the intake and exhaust cam shafts align aswell as the one on the crank.
Dealia is offline
post #4 of 6 Old 05-15-2019, 6:16 AM
nigelrb's Avatar
Quoted: 60 Post(s)
Reputation Power: 3
Re: 954 rattle
Originally Posted by Dealia View Post
No. I thought that might be the case . . .
Well, that part's good to hear. A more knowledgeable power should be along soon!
2007 MV F4 1000R
nigelrb is offline
post #5 of 6 Old 05-15-2019, 6:41 AM
Heeza Y Zasch
unslow1's Avatar
Quoted: 372 Post(s)
Reputation Power: 56
Re: 954 rattle
Both my RR2 & RR3 are quite rattly until the oil has cycled. Although each is surely due for a valve adjustment, I've come to accept that they're just "noisy" at start-up.
unslow1 is offline
post #6 of 6 Old 05-15-2019, 12:02 PM Thread Starter
Re: 954 rattle
Thanks for the feedback guys. I've heard from several other people who own/owned 54s', and they also said that it is completely normal, but I've never had a bike with this much noise.
Guess i'll just ride it and see if it gets worse or not.
Dealia is offline
Tags
954rr , cam chain tensioner , fireblade , rattle cct 900rr top end
954 with rattle sound at 4000rpm and up white.akita Honda FireBlade 3 07-11-2018 4:04 PM
rattle under acceleration warloks38 Honda FireBlade 0 07-11-2018 2:40 PM
02 954 Low Speed Driveability Issues JMooreHarrier2 Honda FireBlade 27 06-26-2018 11:06 PM
2002 954 w/Ohlins For Sale! $4700 OBO in Wisconsin davef Motorcycles For Sale 2 05-18-2018 9:15 AM
2003 954 power issues Kylep7888 General Discussion 4 05-12-2018 4:59 PM
