1995 cbr900rr starts when tilted? - Honda Motorcycles - FireBlades.org
post #1 of 3 Old 08-21-2019, 10:57 AM Thread Starter
Hello every one Love the cbr 900rr awesome bike. Problem free for 7 years but all of a sudden I'm having issue when starting. After I take a long ride bike will only start if I lean bike over to the left, very weird. If i put kick stand down and hold start button it will only start when bike leans over to rest on stand. I don't think the stand has anything to do with it because when the stand is up and I move to the left it does the same. Not sure if there is a sensor or something.
I should clarify, it does not TURN over till I tilt it. When it's tilted it turns over and starts as it should .
Thanks
Cloned1973 is offline
post #2 of 3 Old 08-21-2019, 2:32 PM
nigelrb's Avatar
Quoted: 174 Post(s)
Reputation Power: 7
Send a message via Skype™ to nigelrb
Re: 1995 cbr900rr starts when tilted?
Huh?
Deja vu?
Didn't I read this elsewhere?
2018 CBR1000RR SP2 / 2004 CBR1000RR / 2003 CBR954RR / 2001 CBR929RR (Erion Racing Edition)
1985 Honda VF1000R / 1985 Honda NS400R
2007 MV F4 1000R / 2020 Daytona 765 Moto 2 Replica (on order)
nigelrb is online now
post #3 of 3 Old 09-04-2019, 5:16 AM
Quoted: 21 Post(s)
There is safety cut off switch for the kickstand. Does the side-stand light on the dash come on when bike is upright and having this issue? Does your side stand-light work at all?
Check to see if starter is getting voltage when bike is upright, if so, faulty starter.
I would check starter button, ignition switch, kill switch, then wiring.
But since this happens after a "long ride", I would assume heat and expansion is involved. So I would suspect starter and side stand switch first. Buy a cheap multimeter and learn to check for voltage, very easy to do.
Can also very easily be loose wiring.
dualheadlamps is offline
