03 954RR HOW TO TEST IF ECU IS STILL GOOD - Honda Motorcycles - FireBlades.org
post #1 of 5 Old 09-07-2019, 6:39 AM Thread Starter
Quoted: 3 Post(s)
I have a 03 954rr that will crank but wont start completely. I have no spark and i keep hearing that i need to test my ecu but i have never used a volt tester... someone please help me and tell me how i can fix this.
_60A6149_1567849160729.jpg‎
jpocampo is offline
post #2 of 5 Old 09-07-2019, 8:36 PM
Quoted: 749 Post(s)
Reputation Power: 102
Re: 03 954RR HOW TO TEST IF ECU IS STILL GOOD
What have you done to test components? Do you have a service manual? Are there any codes? Does the fuel pump prime, can you hear it? What were the circumstances before it died?
IanDoohan is offline
post #3 of 5 Old 09-10-2019, 7:44 PM Thread Starter
Quoted: 3 Post(s)
I had a friend that helped me test the wiring. Most of the wiring where working but now my fuel pump is not... everything was working before i ran into issues where i was getting no spark in my plugs.....
jpocampo is offline
post #4 of 5 Old 11-24-2019, 7:19 AM Thread Starter
Quoted: 3 Post(s)
Tried everything but still no spark please help....
jpocampo is offline
post #5 of 5 Old 12-05-2019, 12:16 AM
Quoted: 2 Post(s)
Try the bank angle sensor or the camshaft position sensor. That is if you've checked the obvious fuses and relays first. Usually isnt the kill switch. Your looking for a bad component of the starting system. Theres only a limited number of things it can be..
Jason95826 is offline
