02 954 cranks but no start, help - Honda Motorcycles - FireBlades.org
post #1 of 3 Old 09-09-2019, 7:42 PM Thread Starter
Quoted: 3 Post(s)
have a 2002 954 that will crank but not start. Problem started out as the bike WOULD crank….then die off like battery not getting juice.
Tested battery and is OK. Since then I have replaced: the stator, regulator, starting motor, and spark plugs.
Currently the bike just turns over and will not start. It doesn’t go dead anymore, just cranks. Fuel pump is priming and sounds like it always has.
Any input or help is appreciated on what to try next. FPR? Side stand switch?
Thank you!
Kkkdean is offline
post #2 of 3 Old 09-10-2019, 11:54 AM
Heeza Y Zasch
unslow1's Avatar
Quoted: 388 Post(s)
Reputation Power: 59
Re: 02 954 cranks but no start, help
I'd check for proper valve seat & clearance...
...that is, if the above stated is within spec
unslow1 is offline
post #3 of 3 Old 09-10-2019, 1:51 PM
Quoted: 55 Post(s)
You replaced the plugs, but did you check that you were getting a spark? Are you getting fuel, e.g. do plugs get wet?
BenelliBlade is offline
