02 954 valve check - Honda Motorcycles - FireBlades.org
post #1 of 5 Old 11-29-2019, 10:02 AM Thread Starter
Quoted: 4 Post(s)
02 954 valve check
Hey guys, 02 954rr that just turned 16,000 mi. I have in hand an OEM CCT (yes I wanted to go OEM) and a valve cover gasket set. I also have a manual but haven't studied it in detail just yet.
Just looking for tips/tricks, anything I should have beforehand, special tools or feeler gauges that make the job easier? I have the short standard type right now.
Buttoning up another project ATM but this is next on the list.
rOob is offline
post #2 of 5 Old 11-29-2019, 11:32 AM
nigelrb's Avatar
Quoted: 221 Post(s)
Reputation Power: 7
Send a message via Skype™ to nigelrb
Re: 02 954 valve check
Bike shouldn't even need a new CCT at 16,000 miles.
Nevertheless, the manual is sufficiently detailed, but this isn't a job for someone with only basic mechanical ability. Valve adjustment (which I presume you'll be doing because of having the valve cover gasket) is by shim, so, ideally, you'd need to have a range of shims at hand, or the ability to get them quick unless your bike is remaining off the road for a while.
For info, most owners report that on the 16,000 mile service, very rarely do valves need adjusting.
nigelrb is offline
post #3 of 5 Old 11-29-2019, 12:36 PM Thread Starter
Quoted: 4 Post(s)
Thanks for the response! Ive done cam swaps and valve work in other vehicles but this will be my first bike. I have read, on this board and others, some frustration with how compact the engine workspace is. The bike is put up for the winter so i have no need to rush. It would be great if no action was necessary but i still want to check anyways!
rOob is offline
post #4 of 5 Old 11-29-2019, 1:11 PM
Quoted: 49 Post(s)
Then again 16k miles is the cam chain replacement interval for my Benelli
BenelliBlade is offline
post #5 of 5 Old 11-29-2019, 2:28 PM Thread Starter
Quoted: 4 Post(s)
I mean i figured it would be a good time to do it. I know there are a lot of complaints on noisy cct's, $60 doesnt break the bank...
rOob is offline
