Fireblade 2003 coil connector - Honda Motorcycles - FireBlades.org
 1Likes
  • 1 Post By BigdaddyPaz
post #1 of 5 Old 12-15-2019, 4:51 PM Thread Starter
Where do I connect this wire? It is the black/white from the ignition coils. Is it ground or 12V?
Regards
DA9D9F58-A767-40CE-AA07-E7C4269E5A01_1576443033767.jpeg‎
toto1 is offline
post #2 of 5 Old 12-16-2019, 8:31 PM
Quoted: 103 Post(s)
Reputation Power: 9
Re: Fireblade 2003 coil connector
Im almost positive that's your service or jumper to test your bike. I believe its something the shops "use" to use to check your diagnostics
nigelrb likes this.
BigdaddyPaz is offline
post #3 of 5 Old 12-22-2019, 8:03 AM
Quoted: 43 Post(s)
Looks like there is only one wire is that right?
Wires that are Black with White trace is 12v switched and feeds injectors and coils (and some other circuits too) which are then “earthed” by the ECU.
The only red connector I remember has two wires and goes to the crank position sensor on the rh crankcase.
The diagnostic connector has 2 wires and is black.
machinehead is offline
post #4 of 5 Old 12-22-2019, 6:55 PM
Quoted: 749 Post(s)
Reputation Power: 102
Regards
There should be another wire/connector in that area near the starter solenoid.
IanDoohan is offline
post #5 of 5 Old 12-23-2019, 11:15 PM
Quoted: 49 Post(s)
Reputation Power: 48
on my 03 the diagnostic port is all black. so i dont think thats it!
954Kevin is offline
