chain question - Honda Motorcycles - FireBlades.org
post #1 of 30 Old 01-15-2005, 2:05 PM Thread Starter
chain question
I just went out to clean the bike and noticed that the chain has little surface rust on the rollers. I guess I have not been lubing it as well as I should have. There there something I could do to clean it up or should I worry about it. I did just relube with Honda chain lube. Do I have to replace the chain? The chain has 3k miles on it.
Any suggestions?????? any advise.........
colryn is offline
post #2 of 30 Old 01-15-2005, 2:12 PM
Re: chain question
Oh, thought you were calling me. Never mind.
OK, seriously now... try soaking a shop rag in WD40 and working the chain through your clenched hand with the bike on a rear stand. That should remove most of the rust you're talking about. And no, you shouldn't have to replace the chain if you're only dealing with unsightly surface rust as you've described (and the chain has no stuck links or damage beyond what you've described).
Chain is offline
post #3 of 30 Old 01-15-2005, 2:22 PM
Rigor's Avatar
Re: chain question
agreed. when finished, (it sounds as if your bike sits outside?) spray the chain with a liberal coat of WD40 and leave it there to avoid further surface rust..........
Rigor is offline
post #4 of 30 Old 01-15-2005, 2:24 PM
sheepofblue's Avatar
Reputation Power: 48
Re: chain question
And remember to clean it with the engine OFF on the stand (sorry there are people this is not obvious to)
Must obey the sheep dog
sheepofblue is offline
post #5 of 30 Old 01-15-2005, 2:35 PM
HondaGalToo's Avatar
Reputation Power: 32
Re: chain question
Yeah, I was thinking the same thing. I saw the aftermath of someone who had decided to clean the chain with the bike running. It wasn't pretty.
HondaGalToo is offline
post #6 of 30 Old 01-15-2005, 3:15 PM
CBR929RE's Avatar
Reputation Power: 39
Re: chain question
get the grunge brush and go to work with some wd40 if the rag doesn't work. then obviously take it for like a 15 minute ride to dry off and warm up the chain then relube it and let it cool.
CBR929RE is offline
post #7 of 30 Old 01-15-2005, 3:54 PM
Re: chain question
I donno what a grunge brush is but you shold never use a hard brush cause it damages the o'rings don't ask me how I know
l'timbré is offline
post #8 of 30 Old 01-15-2005, 4:08 PM
CBR929RE's Avatar
Re: chain question
its a special brush made for motorcycle chains. does seem like it has hard bristles but it says its o-ring safe http://www.grungebrush.com/
CBR929RE is offline
post #9 of 30 Old 01-15-2005, 4:15 PM
Rigor's Avatar
Re: chain question
if you're stupid enough to consider cleaning it with the engine running, AND IN GEAR, then by all means.....please do. remember to keep the garage door closed, as well. natural gene-pool clensing.....
oh........and use your toothbrush.............you won't be needing it afterwards, anyway.............
Rigor is offline
post #10 of 30 Old 01-15-2005, 4:32 PM
Re: chain question
Yeah, right? I don't understand what people are thinking sometimes. Or, not thinking.
post #11 of 30 Old 01-15-2005, 4:34 PM Thread Starter
Re: chain question
Actually no. It is always garaged kept. I forgot to mention that I washed it with soap and water last week. I made sure to dry everything off and I even used a air compressor to make sure everything was completely dry. I now realized that I forgot to do the same with the chain. I will try and re-clean with WD40 and re-lube.
BTW: thanks for the info on the grunge brush. I knew I could count on the org to help me spend my money. You sum bitches are going to be the death of me.
Thanks for the help
colryn is offline
post #12 of 30 Old 01-15-2005, 4:40 PM
CBR929RE's Avatar
Re: chain question
Thanks for the help
doesn't this site suck in that regards? glad I could help, its less than $15 so thats one of the smaller spending suggestions on here.
CBR929RE is offline
post #13 of 30 Old 01-15-2005, 4:58 PM
Rigor's Avatar
Re: chain question
Thanks for the help
not trying to bust on you, but try to avoid using an air compressor to dry your bike, near things like seals, or o-rings. the forced air can actually blow air and water past the seals or o-rings, into places you don't want it. use low air psi in those areas............
i use the compressor to knock the large amounts of water off and try to towel dry as much as possible. you prolly do the same, just throwing that out there....... your results may vary. mastercard and visa excepted. sorry, no american express.
Rigor is offline
post #14 of 30 Old 01-15-2005, 6:01 PM
Re: chain question
And I suppose you and Rigor have never done anything stupid, me neither I stated that for the 'other' people.
post #15 of 30 Old 01-15-2005, 6:54 PM Thread Starter
Re: chain question
Ah crap, all I have is Discover. Sorry. Will catch you next time around.
Good info on the air hose. I will use with caution next time.
Thanks......
colryn is offline
fork oil and chain question Paul Honda FireBlade 7 06-22-2004 4:48 AM
Yet another chain question! TCD General Discussion 1 06-18-2004 1:40 AM
New chain Installation Question cbr900rr-FB Honda FireBlade 4 04-05-2004 8:42 AM
Just received my 520 RK chain / sprocket kit..question? Joachim2311 Honda FireBlade 7 04-03-2004 1:57 AM
Chain 'when to replace' question SuperDave Honda FireBlade 16 10-25-2003 5:52 PM
