06 cbr 1000 F1 code??? - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 03-14-2008, 11:47 AM Thread Starter
I just put a slip on exhaust on last night, and when i started it back up i have a F1 flashing on the gauge and i have no clue what it is or how to fix it.can anyone help me out? thanks
cbrchris is offline
post #2 of 7 Old 03-14-2008, 7:39 PM
Reputation Power: 59
Re: 06 cbr 1000 F1 code???
If you take the can off and put the OEM one on, does the FI Light go off?
Could it be because the bike isnt set up to the after market can??? How many times does the FI light flash e.g. 3 blinks, 2 long ones etc
Twincam is offline
post #3 of 7 Old 03-14-2008, 9:49 PM
When you installed the aftermarket can, what did you do with the exhaust gas control valve cables? It is OK to remove the cables from the pulley at the engine behind the left mid fairing. However, if you remove the pulley at the engine, the ECU will trip a fault code. Not sure what the code is though.
segiano is offline
post #4 of 7 Old 03-15-2008, 6:13 PM Thread Starter
Ijust left the cables on so they kind of just hang there. if i take the cables off will that make the code go away?
cbrchris is offline
post #5 of 7 Old 03-15-2008, 8:39 PM
Taking the cables off will not effect the code. Removing the pulley at the engine will cause a code. Your code must be something different. Can you describe the code that is flashing? Number of blinks and longs.
segiano is offline
post #6 of 7 Old 03-20-2008, 12:27 PM Thread Starter
my light flashes 3 long, then 4 short???
cbrchris is offline
post #7 of 7 Old 03-20-2008, 8:08 PM
This code indicates a problem with the EGCV servomotor. The first thing the manual suggests is to check the 6P connector at the servomotor to make sure it is seated properly. 3 long and 5 blinks indicates that the servomotor is locked. This suggests that the cables you left hanging at the EGCV may be getting hung on something. Check this as well.
segiano is offline
Headlight mod ' 06 CBR 1000 Mdala Honda FireBlade 10 08-11-2009 3:54 AM
06 cbr 1000 stator deezle Honda FireBlade 5 10-13-2007 5:45 PM
Any problems, 06 CBR 1000 ? Renegade929 Honda FireBlade 24 03-04-2007 12:12 PM
06 Cbr 1000 robert200015 Honda FireBlade 22 11-25-2006 7:50 PM
CBR 1000 '06 thirdoption Introductions 7 06-13-2006 5:41 AM
