2006 CBR 600 RR sputters out after it heats up - Honda Motorcycles - FireBlades.org
post #1 of 8 Old 10-18-2013, 1:16 PM Thread Starter
I have an 06 CBR 600 RR that I bought new and now has just under 10k mi on it. I have recently replaced the battery and air filter. Now here is the problem I am running into. it starts right up like a champ every time with no hesitation and idles just fine for the first few min until it starts to heat up. once it hits 100' the idle starts to slowly go down and once it gets to full op temp the idle starts to crash and the engine starts to sputter until it final just stops. staying on the gas will prolong it for a few min but at that point as soon as I let off the gas completely it dies. I added a fuel system cleaner, but as of yet, have not been able to run a full tank of treated gas through my bike. I don't get to ride nearly as much as i would like due to my new baby boy, but I don't let it just sit either, I do get out and at least start it and run it for a few every few weeks. any ideas on what might be going on or ideas of where to start with trouble shooting? any ideas would be greatly appreciated since this is my first foray into motorcycle forums.
jjbrewing is offline
post #2 of 8 Old 10-18-2013, 1:38 PM
Re: 2006 CBR 600 RR sputters out after it heats up
Maybe the starter valves.
Is the radiator full?
How old is the fuel?
post #3 of 8 Old 10-18-2013, 1:53 PM Thread Starter
fuel is a bit old but it has sta bil in it so I think it should be fine. but replacing the fuel prob isn't bad idea anyway. as for the starter valves, I would have to look deeper into it as at the moment, I think that may be beyond my technical skill. I havnt checked the radiator but I will. it doesn't show to be over heating though.
post #4 of 8 Old 10-18-2013, 4:11 PM
Reputation Power: 32
What you're describing sounds like a rich condition at idle... is there a particular RPM you get to, where the issue seems to disappear? Basically, how does it run from, let's say, 2000 RPM and above?
You did just change your air filter... did you replace it with the same air filter type as what was in there before?
How are your spark plugs looking?
Lastly, has the fueling been modified, like with a PC or other product used for altering your mapping?
JNSRacing is offline
post #5 of 8 Old 10-18-2013, 4:37 PM Thread Starter
runs fine at higher RPM. it starts out around 1500-2000 RPM upon starting then after a few min of idle and engine temp gets to norm idle drops slowly and under 1500-1000 rpm idle it sarts to sputter and run rough and then just cuts out. air filter is OEM, same exact that was in there, so shouldn't be a problem there. no PC mods, engine and exhaust is still stock. i have not looked at the spark plugs yet.
post #6 of 8 Old 10-24-2013, 9:29 AM
Reputation Power: 17
If you don't ride that much you might be fouling up the Oxygen sensor causing a miss read making the computer think it's lean, so it's dumping fuel.
Check your plugs for the colour of the ceramic insulator
Bluevitz_RS is offline
post #7 of 8 Old 10-24-2013, 10:48 AM
Reputation Power: 113
The o2 sensor doesn't do that much. The ECU only even looks at its reading at steady throttle+low load+constant speed. It's not a wideband designed to compensate for different flows etc.
Sky91 is offline
post #8 of 8 Old 10-24-2013, 10:50 AM
Ok, other problem could be temperature competition. If the intake temp is reading too low the computer should compensate with additional fuel.
sputters on take off NewportSpeed General Discussion 9 09-21-2012 1:28 AM
Honda 954rr wont start when it heats up!! help please Ayousri Honda FireBlade 3 07-09-2011 12:03 AM
05 VTX 1300 sputters dillardjoseph Honda Cruisers 1 11-02-2010 7:34 AM
98 RR sputters after top speed run. alcopaulic Honda FireBlade 4 07-26-2008 3:00 AM
929 Stator and wiring - It heats up a LOT. ShadeZ Honda FireBlade 1 07-26-2006 3:26 PM
