02 f4i stumble, rough idle - Honda Motorcycles - FireBlades.org
post #1 of 3 Old 06-05-2016, 3:18 AM Thread Starter
I have an 02 f4i, has arrow carbon exhaust, k&n filter, pc3 idle is rough and trying to drive in traffic under 5k it sounds like it's running on two or three cylinders, changed plugs, fpr, checked all connections and vacuum, removed pc3 no change, if I disconnect the map sensor the idle gets normal and the bike sounds better, I have no f1 light, I am also getting 100 miles to 115 per tank....please help, I would just change the map sensor but I did that with the fpr and no change
Chudler87 is offline
post #2 of 3 Old 06-05-2016, 3:20 AM Thread Starter
Re: 02 f4i stumble, rough idle
Btw sputter happens under light throttle only as in rolling into the throttle or maintaining speed under 5k
post #3 of 3 Old 06-05-2016, 3:44 PM
Step 1 Easy. Open the PC map, use zeros (0) in the first 2 columns on the left side. Save changes and reinstall map.
Step 2. Hard. Remove pc from bike = test ride to see if sputter clears.
Catch22 is offline
Tags
f4i , hesitation , misfire , sputter
rough idle Kaniving1987 Honda FireBlade 7 09-30-2015 8:21 AM
CBR 954 Rough idle, and bike is rough until 3000 RPM's Tree954rr General Discussion 2 07-20-2015 4:37 PM
Rough idle.. Wanderingmiles Honda FireBlade 14 05-27-2014 1:16 PM
Rough idle on my 929 CBR_Mike929rr Honda FireBlade 2 10-11-2013 2:46 AM
Rough idle on F3!? blkpitbull Honda CBR 600 2 10-26-2008 10:09 AM
