96 F3 Idle creeps up to 5k - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 07-31-2016, 12:28 AM Thread Starter
I've done about everything I can think of. The cables are good I've takin the carbs off and cleaned them up. Reattach and syncing tomorrow. After that I have no idea what it could be so I need more things to check if it's not the carbs needing synced.
IdleF3 is offline
post #2 of 7 Old 07-31-2016, 7:06 AM
Quoted: 759 Post(s)
Reputation Power: 102
Re: 96 F3 Idle creeps up to 5k
Cleaned them like this?
Sounds like a fuel problem, when did this problem arise? How's your compression?
IanDoohan is offline
post #3 of 7 Old 07-31-2016, 1:01 PM
See Ian's [bottom of the photo] spigots? Once assembled and running, spray contact cleaner or brake clean at those air entry points. Lean air wants to peak and shout off kind of runs out of gas but doesn't.
If you did clean the carbs like the photo, look at the brass throttle plates in the carb body. Assembled, you have the CV slide to lift and see of the brass throttle plates are equal or one is higher than the others. That's a high rev [causing] plate needing to be screwed back down even, or the sync will pickup who is pulling the most vacuum under that plate.
See the 4 plungers at the top left corner of the photo? Those need to have the rubber insert so those plungers are sent home and do not leak. Those too may cause a rev interference where an idle cable is no help.
Catch22 is offline
post #4 of 7 Old 07-31-2016, 1:21 PM Thread Starter
I didn't pull each carb apart I just took the Jets and everything out. I can see a gap in one of my throttle plates though just not sure on how to adjust it so it closes fully. I'll pull them all apart when I get back home. So how do I adjust those when I do get it taken apart?
The problem was there when I bought the bike I just assumed it was a throttle cable. Didn't think it would give me this much of a headache.
IdleF3 is offline
post #5 of 7 Old 07-31-2016, 5:17 PM
Quoted: 759 Post(s)
You need a set of these or similar to see the vacuum each cylinder is reading. Then make you adjustment as noted below:
It's a process, running operating temperature, idle up to 3000 make adjustments, bring idle down to normal, recheck the readings at idle. You're supposed to adjust each fuel/air mix screw individually as well, but most syncs can be done fairly close to perfect without messing with the fuel/mix screws. Just set those to 2.5 turns out from lightly seated. That's a good starting point.
If you look at the #1 carb in my pic (left most carb), on the right side of it you'll see a small screw under spring tension. That screw allows butterfly adjustment. Same on #2, and on #4 it's on the left of the carb. Generally the #3 carb is the carb that you can't adjust, and that vacuum reading is what you try to match the other carbs to.
post #6 of 7 Old 08-01-2016, 1:53 PM Thread Starter
Just updating everyone that I got it fixed last night reattached the carbs and the idle is fixed minus still needing synced. A throttle plate spring between carbs 3&4 was wedged causing the throttle plate not to fully close.
Not my picture but the spring was split halfway in the middle so it was touching both sides.
carb40.jpg‎
IdleF3 is offline
post #7 of 7 Old 08-01-2016, 3:40 PM
Quoted: 759 Post(s)
YAHTZEE!!
NEED HELP WILL NOT IDLE !!!!!!!! 2002CBR954RRJAM Honda FireBlade 21 11-16-2011 12:07 PM
idle? Bike D General Discussion 0 07-24-2010 4:50 PM
I NEED HELP WITH IDLE mettaluv General Discussion 15 05-22-2009 5:19 PM
Your idle? maxgee Honda FireBlade 12 09-18-2007 4:44 PM
