99 f4i motor hard to turn - Honda Motorcycles - FireBlades.org
post #1 of 2 Old 02-06-2017, 9:11 PM Thread Starter
I recently purchased a 99 f4i motor that had a stuck piston. I pulled the head and with a combination of tapping the piston heads (gently) with a block of wood and putting pressure on the flywheel bolt it came loose. After it was free it turned fairly easily, I could turn it over with a hand on the flywheel. There was, however, some resistance. I put the head back on and put it in time according to the owners manual. With everything back together the starter won't turn it over. I have a brand new battery, no plugs in the holes and without the reduction gear on the starter (no resistance) the starter spins freely. I can turn the engine over with a wrench on the flywheel bolt with about 30 ft-lb of force (that is an estimate). During the freeing of the engine I never got into the crankcase.
I think my problem is one of the following but I'm not sure -1. I have done something wrong with the timing and it is making it hard to turn. 2. All motors are like this and I just need a new starter. 3. Bad bearings/ crank problems.
I am a complete newbe to motor work and would appreciate any input, Thanks.
allejp2 is offline
post #2 of 2 Old 03-15-2017, 9:04 PM
Re: 99 f4i motor hard to turn
I don't really have much experience rebuilding motors but I do have a fairly extensive background in mechanical repair. In my opinion you probably should've fully disassembled the block to inspect all parts to see if there is an underlying issue that caused the stuck piston and replaced anything worn while it was apart. How many miles are on the motor?
"Jesus loves me! Otherwise I'd be dead already."
Rdot is offline
Tags
crank , fast , motor , piston , stuck
starter motor wont turn tunil Honda FireBlade 4 07-27-2009 10:34 AM
F4i hard to start and stalls when using throttle TheJackal Honda CBR 600 2 09-05-2008 12:08 PM
CBR 600 F4I HARD TO START AND WONT REV OVER 5000 RPMS phucker Honda CBR 600 2 06-27-2008 10:47 PM
Turn on Hazard Light for 2003 F4i basicblaq Honda CBR 600 2 05-16-2008 11:32 AM
MOTOR DOESNT TURN PLEASE HELP marius General Discussion 4 04-30-2008 1:13 AM
