Pulling carbs is like pulling teeth - Honda Motorcycles - FireBlades.org
 8Likes
  • 1 Post By IanDoohan
  • 1 Post By Cruizer67
  • 2 Post By Cruizer67
  • 1 Post By Bishk
post #1 of 12 Old 06-01-2018, 12:30 AM Thread Starter
Quoted: 6 Post(s)
So I am trying to pull the carbs off this 96 F3. Not knowing too much about the bike. I have no idea when the last time anything came apart. I am thinking that the rubber boots from head to carb are super hard and no longer pliable. Any one have any suggestions as to how I go about getting the carbs off. ? Is there a way to soften the boots. Or do I just pull and tear and replace boots. ?
Thanks for any info.
Cruizer67 is offline
post #2 of 12 Old 06-01-2018, 1:38 AM
Quoted: 692 Post(s)
Reputation Power: 102
Re: Pulling carbs is like pulling teeth
If they’re original they probably are a little petrified. On my 93 900RR I got into the habit of only loosening the clamp that attaches the insulator (rubber boot) to the head, thus giving me a little bit of leverage to rock them back and forth and eventually free them from the head. You aren’t experiencing anything out of the ordinary. They are a BEAR to get off, especially at this age (them, not you).
That being said, I know there is even less room to maneuver on the 600’s. I generally recommend a heat gun to try and warm them up a bit, but if you're serious about making it easier for next time, I would just cut them and replace with new ones. One thing I’ve learned about these old girls is that you’re never into the carbs just once.
Duncan893 likes this.
IanDoohan is offline
post #3 of 12 Old 06-01-2018, 10:19 AM Thread Starter
Quoted: 6 Post(s)
Thanks Ian .. I was thinking that cutting them would be the best idea.. they could be 30+ yrs old and no sense dealing with old hard rubber..
IanDoohan likes this.
post #4 of 12 Old 06-05-2018, 4:27 PM Thread Starter
Quoted: 6 Post(s)
Finally got the carbs off. Was able to save the boots so that?s a good thing. Opening up the float bowls showed just how long this thing sat.
7A5875D7-7F88-4346-B771-235217989B6B.jpeg‎   BC1645B5-0BB7-4881-9851-D44C0502E5CC.jpeg‎   E1A1CBFA-CEF6-4ECB-B4C1-1A43B22FA223.jpeg‎
IanDoohan and MrPickwick like this.
post #5 of 12 Old 06-12-2018, 10:34 AM Thread Starter
Quoted: 6 Post(s)
Carbs are back on and doing a test fire. Have some things that I need to check out. But at least it runs. Runs crappy. But it runs.
File Type: mov 58B61EAD-586C-4165-BD8A-371DBD0FE0A7.MOV‎ (10.60 MB, 12 views)
MrPickwick likes this.
If it doesn’t exist I can make one
post #6 of 12 Old 06-12-2018, 10:54 AM
Quoted: 487 Post(s)
Well done matey
MrPickwick is offline
post #7 of 12 Old 06-13-2018, 1:48 PM
Quoted: 692 Post(s)
Don't know if its just the video sound quality or not, but sounds like a twin, or triple at best lol - spray some brake cleaner on each header to see if they're all firing properly. A nice hot header will flash burn the cleaner clean off. Or, use a laser infrared temp taker
Either way, one step closer to being ridden
post #8 of 12 Old 06-13-2018, 4:32 PM
Quoted: 20 Post(s)
Reputation Power: 15
great you got her started, by the sounds of it I think your main jets are still blocked, is say this because when you tried to rev it it died, I had the same issue with a blade I was/am rebuilding
jon 8214 is offline
post #9 of 12 Old 06-13-2018, 4:40 PM Thread Starter
Quoted: 6 Post(s)
Thanks Ian it has been noted as a thing to do.. getting it started was the main step in the process for me .. knowing that it will run was my main goal.. Time permitting I will get around to checking.
post #10 of 12 Old 06-13-2018, 4:44 PM Thread Starter
Quoted: 6 Post(s)
Thanks for the reply Jon. I know that the carbs will need to come off again so that I can re-clean them. Going to run a little injector cleaner through the carbs and hopefully it will loosen some of the stuff up .. as I noted above making sure it ran was the main goal of this exercise so that i knew it was worth continuing..
For the rest of the members who read this.. all advice will be looked at and applied where it seems that it would be helpful
I appreciate all the help and guidance
Bernard
post #11 of 12 Old 06-13-2018, 4:46 PM
Quoted: 20 Post(s)
Bernard
Good idea Bernard, when you reclean them, pull a strand of wire out of a wire brush and push it through the main jets, its a very small hole so doesn't take much to block it but the wire is thin enough to go through it
jon 8214 is offline
post #12 of 12 Old 07-16-2018, 3:15 PM
Quoted: 2 Post(s)
I know this is late but use fishing line instead of wire. You can use different sizes and it wont scratch.
Bishk is offline
