Strange radiator overheating - Honda Motorcycles - FireBlades.org
 1Likes
  • 1 Post By Middleweight600
post #1 of 3 Old 09-19-2019, 12:07 PM Thread Starter
Quoted: 3 Post(s)
My 05 f4i has had a strange overheating problem; after about 45 min of everything acting normal temps going up, then settling etc... My bike starts ticking up in temp all the way to 240 and boils over. I did a compression test, changed my thermostat and cannot find what's causing this!! I had this same problem last year when I lived in a different state and a local shop fixed it and I haven't had an issue until I changed my coolant myself. I've flushed it several times no air bubbles, no leaks. Could it be I did something to the water pump???
Middleweight600 is offline
post #2 of 3 Old 09-19-2019, 5:22 PM
Quoted: 696 Post(s)
Reputation Power: 102
Re: Strange radiator overheating
It could be the pump is not pumping. Obvious signs to look for is coolant flowing through the radiator via an open cap, or drain the system, pull a hose off the pump and thumb the starter to see if the propeller/impeller is turning in the pump. Could be a clogged hose. You might need to pull everything apart to the system.
My Red Rocker 93 Build Link: Cafť 900RRP
IanDoohan is offline
post #3 of 3 Old 09-24-2019, 11:50 PM Thread Starter
Quoted: 3 Post(s)
Think I found the culprit, the radiator side of where my cap goes on is a bit mangled and leaking; I tried bending everything back and got her to 230*F with no boil....
nigelrb likes this.
