95 f3 serious electrical issue!!! - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 09-26-2008, 8:21 PM Thread Starter
I am having the hardest time trying to figure out why my CBR600 F3 kills on me. I have read through a ton of past post to see if something is close but couldn't find an answer so sorry if this isn't new. PROBLEM: When I start on a cruise with a freshly charged battery and I'm only out for half hour or so in town, when I come to stoplights and pull the cluch in the bike will die. The only way to keep it running is to keep the rmps up by throttling it. Sometimes when I get to my destination shut it off and try to restart it, its dead. I can push start or jump start it to get it running again. Now, so I take it home and run some test on it. Sometime when I get it home the bike will stay running on its own. From the many test I have run on the stator and RR and ground nothing seems to be wrong. I tested it again today and decided to add a ground from the RR directly to the battery.
If anyone has some new suggestions to try I would greatly appreciate it!
Thanks!
milles9 is offline
post #2 of 6 Old 09-26-2008, 8:28 PM
Quoted: 198 Post(s)
Reputation Power: 25
Re: 95 f3 serious electrical issue!!!
The battery should be put under a load and tested. If the battery is good, that means stator or the regulator. If the batter is a few years old, then it might be time for a new one.
There are only three components; battery, stator and the regulator. A failure on one can cause a failure on the other(s) as well.
lanbrown is offline
post #3 of 6 Old 09-27-2008, 12:19 PM Thread Starter
I've had the battery tested and was told it is good. I also bought a new one and put it in but that didnt help so I returned the battery. Ive found a couple tests for both the stator and rectifier and when I test them it shows there is nothing wrong.
milles9 is offline
post #4 of 6 Old 09-27-2008, 12:59 PM
Quoted: 198 Post(s)
Milles9,
If all three show nothing is wrong; then the problem is a figment if your imagination. You can get misleading readings at times from the components. I have also heard of people having a battery tested and it passed but their issues went away with a new battery.
The strongest weakness that Honda has is their voltage regulator. Might try replacing it with an aftermarket one and see if that solves the issue.
lanbrown is offline
post #5 of 6 Old 09-27-2008, 1:05 PM
Send a message via AIM to int76 Send a message via Yahoo to int76
had a similar issue 4 or 5 years ago and ended up being a bad coil pack. Give the coils a test.
int76 is offline
post #6 of 6 Old 10-11-2008, 1:02 PM Thread Starter
Well I bought a new rectifier with heatsink fins and that seems to have fixed the problem. Thanks to everyone who commented. For those that have a similar problem one thing I've also noticed corrected itself after RR replacement is that my speedometer used to be over by about 5 mph and now its almost dead on. FYI
milles9 is offline
Unresolved electrical issue Geckohunt Honda Naked Sportbikes 4 12-29-2008 5:56 AM
Electrical issue c-hill803 Honda CBR 600 1 06-12-2008 11:12 PM
electrical issue battery not charging gaz1012 Honda FireBlade 6 04-13-2008 3:48 PM
95 cbr f3 issues... electrical? germain813 Honda CBR 600 5 09-26-2007 11:01 PM
need some help - 929 electrical issue zxcv1000 Honda FireBlade 0 06-28-2006 8:25 PM
