96 cbr f3 starts but wont run - Honda Motorcycles - FireBlades.org
post #1 of 2 Old 11-04-2008, 10:49 AM Thread Starter
I have 96 honda cbr600 f3 that has been running fine up until now. i was riding and it suddenly stopped as if it had run out of gas. i can get the bike to start for a moment but as soon as i twist the throttle it shuts off instantly. i was told it might be the fuel pump. any suggestions?
pyroman120 is offline
post #2 of 2 Old 11-06-2008, 5:16 PM
Reputation Power: 29
Re: 96 cbr f3 starts but wont run
Check the fuel pump contacts.
The pump is easily accessible on the left side of the frame.
It'll probably be a Mitsubishi electro-mechanical unit (3 diamond symbol on the black cover).
undo the black screw that holds the black plastic cover, allow the wires to move in whilst gently pulling partially off - do not pull hard or you may damage the wire connections.
At the back end you will see a pair of contacts; check the condition of these they may be pitted or partially burnt away. If there is still a decent amount of metal pad on each side it is possible to dress up and square up the faces to each other using a flat nail file.
If the contacts are shot like the ones in the picture then a new pump is needed or pick one up at a breakers but check the contacts before you buy.
PEM-954 is offline
96 CBR F3 start problems flash78738 Introductions 17 09-06-2008 12:54 AM
96 F3 wont idle 96F3-Matt Honda CBR 600 12 09-03-2008 7:03 PM
Bike starts but wont stay started 95erion General Discussion 2 05-09-2008 1:40 PM
My 96 Honda F3 wont start! Help! chevyoffroad Introductions 1 02-28-2007 8:37 AM
starts but wont stay on defynd Honda CBR 600 2 06-01-2005 9:29 AM
