98 CBR F3 issues - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 12-12-2008, 9:28 PM Thread Starter
Re: 97 CBR F3 won't start
hey guys i really need some help in figuring out just what is goin on with my bike. i have a 98 f3 and i think one of the problems might be the rr. pretty sure thats one of them. the other one might stump some of you as it has done to me. i was takin the fuel tank off one day because my keys fell out of ignition on the way to work. (anothe problem soon to be fixed). when i put everything back together i had trouble getting it to start so i jumped it. got it running and took it around the block. i noticed that if i would give it too much throttle it would cut out and not go any faster. so i was coming up to a stop sign so i use the front brakes to slow down. when i pulled the front brake lever the bike took off and scared the hell out of me. i wasnt expecting it.so thats where i got confused. if anyone can help me it would be greatly appreciated. like i said it has me stumped because i have NEVER heard of this happening to anyone. thanks guys
rich98f3 is offline
post #2 of 6 Old 12-12-2008, 9:46 PM
Quoted: 198 Post(s)
Reputation Power: 25
Re: 98 CBR F3 issues
I moved this post from the thread it was placed in as it had nothing to do with the original thread.
lanbrown is offline
post #3 of 6 Old 12-12-2008, 10:10 PM
Just grab the hooks to increase speed and open her up to slow it on down. Simple.
Weasle1000RR is offline
post #4 of 6 Old 12-14-2008, 4:44 PM
Reputation Power: 29
Faulty R/R unit is a common charging problem as they over heat & burn out but can also fry the battery. Don't replace with the OEM part, get the pattern part with cooling fins.
If you have had the fuel tank off make sure you have not trapped / pinched / kinked or blocked the rubber breather pipe, if you have then this will create a vacuum causing fuel starvation. There are 2 tubes from the tank one is the breather the other is the over flow tube check both are ok all the way down from the tank.
PEM-954 is offline
post #5 of 6 Old 12-14-2008, 7:56 PM Thread Starter
yeah i got the rr problem figured out and fixed. the other problem is im not able to figure out why the front brake is controlling the throttle. it bogs until i pull the lever to slow down and then it takes off....thats what im stuck on right now
rich98f3 is offline
post #6 of 6 Old 12-26-2008, 3:07 PM
The front brake is hydraulic / mechanical so I don't think it could be causing the throttle issue. How about just a sticky throttle? When you snap the throttle open, does it close just as quickly (like in less than a half second)? How about when you turn the bars lock to lock... does the throttle return get slower?
Corvus is offline
98 CBR F3 Clean Title dpfoyo06 For Sale 2 09-25-2008 10:46 PM
97-98 Honda CBR 600 F3 tail section Jok3r Honda CBR 600 2 07-09-2008 8:27 PM
95 cbr f3 issues... electrical? germain813 Honda CBR 600 5 09-26-2007 10:01 PM
95 cbr f3 water pump same as 98 cbr 600 water pump? byc_panty Honda CBR 600 1 05-24-2007 3:34 PM
98 900rr having some electrical issues. Soul Honda FireBlade 15 03-21-2007 10:30 PM
