96 Cbr 600f3 No start!!!! please help!! - Honda Motorcycles - FireBlades.org
post #1 of 11 Old 04-12-2012, 9:50 AM Thread Starter
Reputation Power: 11
Alright guy's I'm having alot of headache and trouble here. So here's the story. One of my good buddys just bought the bike about 4 months ago. It was cold when he got it so he would go out every few days and start the bike and let it run and get to full operation temperature. He let the bike sit for about 2 weeks once before starting it again. When he went out to start it again the bike would not start up. It would crank and act like it wants to start up and would never fully fire. So i went and looked at it and it had cheap autolite plugs in it. I suggested new ngk plugs. We put them in and still the same thing as before, cranks but no start. After the we drained all the old gas from the tank that had been sitting awhile and added new gas to it. STILL same thing is happening cranks but still no start. Finally i get the bike to my house and i get the carbs pulled off the bike and clean them and get the carbs put back on and it is still doing the same thing the bike will crank and crank and crank but will not start no matter what. I have pulled all 4 plugs and checked for spark and they all have a nice spark to them and the plugs are wet and smell like gas when i pull them out. I am so confused and stumped right now. Have any of you guys ran into a problem like this before? Also i have unhooked the line comeing out of the fuel pump and hit the start button and gas does come out of it as im cranking the bike. I'm thinking a bad ground wire somewhere or something, but just wanting to get other peoples opinions as well. Thanks guys!!
jacjohnston19 is offline
post #2 of 11 Old 05-02-2012, 6:54 PM
Re: 96 Cbr 600f3 No start!!!! please help!!
Have you tested the battery ?
Is it getting spark (coils)?
slothman is offline
post #3 of 11 Old 05-02-2012, 8:20 PM
Reputation Power: 33
Send a message via Skype™ to 2WheelFury
Test out the battery first. sounds like that is the issue. if not the issue try checking to see if you are getting spark at the plugs. Is the fuel pump relay clicking when u try to fire it up?
02 F4i track build-fully built motor, 600rr swinger and rear master, 1000rr front end and rear shock, akra full exh, pcIII and ign module, HRC radiator and quick throttle, brembo fr master and more
2WheelFury is offline
post #4 of 11 Old 05-15-2012, 9:26 AM Thread Starter
Hey guys i tried testing the battery it was good. then i tested for spark, it was also good. Fuel pump was working properly, and it had compression. I gave up on this bike and my buddy took it to our local dealer and they coudldnt even figure the bike out. It just completly blows my mind that the bike randomly quit working and it is coming to all of this. The dealer is saying it's either in the top end of the motor or the flywheel is bad, but it just sounds like those are completly random guesses to me. I mean this bike has all componets to fire. Spark, Compression, and Fuel it's just not starting and it has racked my brain way to much lol. I work 2 jobs about 16 hours a day and dont have time for something like that right now i just have no idea what it could be.
post #5 of 11 Old 05-15-2012, 11:02 AM
If you put your hand over each carburetor while cranking does the engine suck against your hand?
post #6 of 11 Old 05-16-2012, 11:16 AM
The subject of the choke circuit has not been touched yet - which richens the mixture significantly when engaged.
Did you test to see if moving the choke lever forward and back, actually opens and closes the choke circuit at the carbs? Are you starting it with or without the choke engaged? You did mention the plugs were wet with fuel - is there a heavy fuel smell at the exhaust when you attempt to start it?
I would identify whether or not the choke lever is actually working properly, so that you KNOW for sure whether or not it is engaged when you try to start - the choke may be engaged all the time and you may be just flooding it every time - when you pulled the carbs, did you verify the floats could move freely, and not maybe get stuck? This can add "fuel to the (no) fire", so to speak.
Also, before the first time it wouldn't start, had anybody disconnected any of the plug wires, at the plugs OR at the coils? If these are not corrected right, you will get spark, but not at the right times .
After it has been sitting for a while, long enough for some fuel to evaporate, in the event that it might have been flooded, I would hold your throttle wide open with the choke disengaged (lever toward the front of the bike) and try to crank it over for a bit, not re-twisting the throttle, but keeping it wide open during the whole attempt. This will help it to start if it is flooded.
If that doesn't work, wait a bit, and then (mind you, all this depends on knowing if the choke lever is doing it's job) try to start it with no throttle, and the choke fully engaged (lever toward the rider), and see which one of these methods gets more "catches" - that might narrow down if you're getting too much fuel, or not enough fuel.
One last thing, and this is just a shot in the dark, but, since we don't know your knowledge and skill level with regards to carburetion - when you cleand the carbs, did you remove the mixture screw for the pilot circuit? And, if you did, did you screw them all the way in and leave 'em that way, or did you then back them out 2 - 3 turns? Don't be offended by this question, like I said, we have no idea what you do or do not know about carburetion.
Good luck, and keep us posted!
JNSRacing is offline
post #7 of 11 Old 05-16-2012, 4:20 PM Thread Starter
Yes i actually did check while i had the tank and air box off to see if the choke was working properly and at first it was sticking and i had gotten that adjusted and it was sliding as it should and it still wouldn't fire. I'm an auto mechanic full time, and a go kart mechanic part time in the evenings. I would say I'm pretty knowledgeable about engines, but i will be the first to admit that bikes are not my strong point. The way i look at it though is it's and internal combustion engine. As they are very different they are also very similar as well in my eyes. I do all my own work on both of my bikes. But my buddy actually just got rid of the bike yesterday he traded it for a pretty nice car, so he actually doesn't have the bike anymore. Thanks a lot for all the help though.
post #8 of 11 Old 05-16-2012, 4:30 PM
...But my buddy actually just got rid of the bike yesterday he traded it for a pretty nice car, so he actually doesn't have the bike anymore. Thanks a lot for all the help though.
Now that's how you solve a problem, you give it to someone else!!
post #9 of 11 Old 05-16-2012, 4:32 PM
agreed. let it be someone else's headache.
post #10 of 11 Old 05-16-2012, 4:36 PM Thread Starter
Hey the guy came to him asking him to trade and my buddy was completely 100% honest with the guy. Told him exactly what happened, and what he has done and the guy still wanted the bike. His headache now not mine lol
post #11 of 11 Old 05-16-2012, 4:38 PM
Yeah that's definitely a good way of looking at it. honesty is key and whatever happens after that is up to the new owner. He was aware of the issue(s) at hand so it's all on him now.
CBR 600F3 No start please help jacjohnston19 General Discussion 10 05-15-2012 11:16 AM
naked cbr 600f3 cbr 600 f irish How To Articles 1 11-11-2009 1:38 AM
95 cbr 600f3 kicker415s Honda CBR 600 1 04-22-2009 12:10 AM
98 CBR 600F v 600F3 Are they the same? mark7474 Honda CBR 600 8 02-23-2009 6:54 PM
My comparison with my 929 VS.My Old 600F3 vermontcalbud Honda FireBlade 9 04-09-2008 4:36 PM
