98 f3 cable routing - Honda Motorcycles - FireBlades.org
post #1 of 21 Old 04-27-2012, 9:43 AM Thread Starter
Reputation Power: 9
98 f3 cable routing
Anyone have a good picture of the correct throttle cable routing? I dont think what i pulled off was correct. Lots of wear on the cable sheaths. If you have choke cable routing thatd be fantastic as welll!
...also looking for the correct push/pull setup. Clymer's just tell you to do the opposite of what you did.
ENJAYEF3 is offline
post #2 of 21 Old 04-30-2012, 9:52 AM Thread Starter
Reputation Power: 9
Re: 98 f3 cable routing
LOl it always funny when you see 100 people look at a thread and noone knows
ENJAYEF3 is offline
post #3 of 21 Old 04-30-2012, 11:43 AM
Maybe try searching for an F3 OEM manual then.
It has diagrams of all hose and cable routing.
post #4 of 21 Old 05-01-2012, 9:04 AM Thread Starter
Reputation Power: 9
Damn, your right. silly me.
ENJAYEF3 is offline
post #5 of 21 Old 05-02-2012, 9:03 PM Thread Starter
Reputation Power: 9
Just cant figure out this push cable. the throttle worked fantastic before i added the push cable. Now the throttle doesnt return or snap back like it should. Maybe routing? I dont know
ENJAYEF3 is offline
post #6 of 21 Old 05-02-2012, 9:11 PM
Reputation Power: 33
Send a message via Skype™ to 2WheelFury
did you not have one push and one pull cable before??
02 F4i track build-fully built motor, 600rr swinger and rear master, 1000rr front end and rear shock, akra full exh, pcIII and ign module, HRC radiator and quick throttle, brembo fr master and more
2WheelFury is offline
post #7 of 21 Old 05-03-2012, 12:31 AM
Cables too tight perhaps?
post #8 of 21 Old 05-03-2012, 4:34 PM Thread Starter
Reputation Power: 9
The push cable had a bit of slack in it. It wasnt tight though. Im gonna head out to the garage now, since i got out of work a tad early. Ive been watching youtube videos and searching for manuals. Ive been watching almost any cbr f3 videos and reading and anything under the sun pertaining to underneath the tank or the throttle assemblyin hopes to get a glimpse of the proper way to route them(assuming that owner either has never changed them or they are correct). It cant be that far off, this cant be that difficult.
I had read another thread about this, and the dude decided to only run the pull cable, but was definitely advised against it...the thread died so i dont know if it worked out or not...maybe he met his demise without one. I was told, technically the push cable "pushes" the slides(and or butterflies?) back closed under certain circumstances as a safety feature. As explained.....under the pressure of the vacuum and intake of air, the slides/butterflies could get stuck open. If anyone knows if this is true or not, can add to, confirm, etc. Please do let me know!
ENJAYEF3 is offline
post #9 of 21 Old 05-03-2012, 7:39 PM Thread Starter
Reputation Power: 9
fixed....new problem, new thread
ENJAYEF3 is offline
post #10 of 21 Old 05-04-2012, 10:55 PM
awesome to hear. glad you got it fixed. sorry I was not much help to you on that issue. seems like once you get one problem and fix it another one follows right after. bikes are alot of maintenance though.
post #11 of 21 Old 05-09-2012, 12:30 PM Thread Starter
Reputation Power: 9
thanks for at least checking back in. and yes, after one problem is fixed, its another.
ENJAYEF3 is offline
post #12 of 21 Old 05-09-2012, 4:07 PM
sorry to hear. what other issues are you having??
post #13 of 21 Old 05-10-2012, 2:21 PM Thread Starter
Reputation Power: 9
Doesnt idle without the choke engaged. Idles strong and responsive with the choke on, but dies instantly when the choke lever is moved
ENJAYEF3 is offline
post #14 of 21 Old 05-10-2012, 3:09 PM
Sounds like blocked pilots.
The chokes are seperate circuits.
If you increase the revs while the choke is on and then close the choke while the revs are up can you keep it running at higher rpm?
post #15 of 21 Old 05-11-2012, 12:19 AM
Cable routing up front... Hicksi Honda CBR400RR 6 04-22-2012 5:57 PM
Assistance needed for proper cable routing *CBR929* General Discussion 12 06-19-2010 11:44 PM
954 HTEV cable routing maherj Honda FireBlade 0 02-07-2010 2:14 AM
Cable harness routing in front fairing? HomerSaurus General Discussion 0 12-07-2008 3:14 PM
clutch cable routing BlueToy Honda FireBlade 1 09-19-2003 2:12 AM
