cbr running rough - Honda Motorcycles - FireBlades.org
Honda CBR400RR Discuss the Honda CBR400RR in this section. This part of fireblades also covers the Honda CBR 250 and CBR 125.
post #1 of 8 Old 11-07-2010, 1:03 PM Thread Starter
cbr running rough
hi guys new to the site.i have a cbr 400 nc29 and my problem is it jus aint running right.it starts fine no problem every time but seems to be running on 2 cylinders.i got new plugs and still the same so i cleaned the carbs new air filter and fuel filter went in aswel and still the same.any advice?
cbr 400 is offline
post #2 of 8 Old 11-07-2010, 2:41 PM
Reputation Power: 11
Re: cbr running rough
Are you getting spark from all 4 plugs? The wires and boots might need cleaning up.
Monkeh is offline
post #3 of 8 Old 11-07-2010, 11:17 PM
To determine if a cylinder isn't running just spit on the header pipes as the engine warms up. It will steam off the pipes as they get hot. If one stays wet then it's not firing at all or not running as hot as the others.
post #4 of 8 Old 11-08-2010, 7:22 AM
Surffrog's Avatar
Reputation Power: 109
Also check the plug order again. It's very easy to mix them up.
Surffrog is offline
post #5 of 8 Old 11-08-2010, 8:15 AM Thread Starter
yeah im getting a spark from the 4 plugs and ive tried that with header pipes.two are hot and the other are jus warm.the plug order is ok aswel,tanx for the replies by the way
cbr 400 is offline
post #6 of 8 Old 11-08-2010, 8:50 AM
Are both cold headers on the same coil?
If they are, then swap the coils over and see if they're still not firing.
If the problem switches to the other two pipes then the coil is not working.
post #7 of 8 Old 11-08-2010, 9:06 AM Thread Starter
yeah both cold headers are on the same coil.tanx for that bladeracer i havent tried that so il have a go and see what happens.il get back to u and let u know how i got on
cbr 400 is offline
post #8 of 8 Old 11-08-2010, 9:13 AM
Sounds like the coil then.
Be sure not to mess up the firing order.
Go Back   Honda Motorcycles - FireBlades.org > Honda Motorcycle Models > Honda CBR400RR
rough running pt2 firestorm27 Honda SuperHawk 2 10-18-2010 1:18 PM
I NEED SOME ADVICE, ROUGH RUNNING firestorm27 Honda SuperHawk 2 01-16-2010 2:59 PM
Running Rough blackpool ben Honda FireBlade 6 06-08-2007 5:13 AM
need help - 954 running rough wayfastwhitey General Discussion 1 12-16-2006 10:15 AM
