1984 CM450, Carburetor Trouble - Honda Motorcycles - FireBlades.org
Honda Cruisers Discussion of the Honda Rebel, Honda Shadow, and Honda VTX Motorcycles.
post #1 of 4 Old 07-23-2012, 4:36 PM Thread Starter
Hello,
I searched the forums first, and found a couple of people experiencing the same trouble but I thought I'd ask...
1984 Honda CM450, starts every time, runs at high idle with the choke fully applied, then sputters and dies after less than minute.
The engine has < 3000km on it, no history of rebuilds.
So far we have
  • cleaned and gapped the spark plugs... no fouling
  • cleaned the carburetor and replaced float needles
  • cleaned the interior of the fuel tank and replaced the fuel filter
  • adjusted the idle screw
  • no fuel in the air filter
  • some fuel leaking from carburetor overflow tubes (but not much)
We are taking it in for a carburetor sync and a tune-up, but I'd really like to save a few bucks by doing what I can for it within my level of experience.
Any ideas?
Thanks in advance!
Prototype288 is offline
post #2 of 4 Old 07-23-2012, 4:56 PM Thread Starter
Re: 1984 CM450, Carburetor Trouble
Also... black smoke coming from the right side exhaust... maybe it's a clue...
post #3 of 4 Old 02-12-2013, 3:23 PM
I'm having similar sounding issues with my 1982 cm450C.
I've had the carbs out over the winter and cleaned them out, put the battery on a battery charger, but unfortunately my garage isn't bike maintenance friendly during the winter, here in central Ontario, so i'll check back on this thread when I get it back together in March.
I'm also planning to change the gaskets on the carbs and possibly the engine. My goal is to get it on the road. This will be my first full season on a bike.
I'd be interested to hear how the clean and balance of your carbs helps the bike. Best of luck with that!
rootman450 is offline
post #4 of 4 Old 02-13-2013, 12:31 AM
Black smoke from one exhaust pipe I'd be looking at a failed fuel tap diaphram.
Go Back   Honda Motorcycles - FireBlades.org > Honda Motorcycle Models > Honda Cruisers
carburetor leaking jeepstang1986 General Discussion 4 04-07-2012 3:09 PM
valve issue on cm450 bobbermike Honda Cruisers 2 08-23-2011 10:01 PM
carburetor hondaxr100 Honda FireBlade 4 04-26-2011 11:18 PM
81 CM450 swap to CM400 Frame Offender General Discussion 0 05-31-2010 6:53 PM
Factory Pro carburetor Dunc Honda FireBlade 8 11-29-2007 9:05 AM
