1977 Honda CB750 Hondamatic - Honda Motorcycles - FireBlades.org
Honda Cruisers Discussion of the Honda Rebel, Honda Shadow, and Honda VTX Motorcycles.
post #1 of 2 Old 11-05-2013, 12:19 AM Thread Starter
Hi all,
I am new to the forum. I need some opinions! A friend of mine is selling a 77 CB750 Hondamatic for 1500 bucks. It's in fair condition, not bad of shape considering how old it is. I did some of my own research on "Hondamatics" I love old Hondas. Is this a bike worth buying? I think it would be neat to own.
I saw the bike in person, everything works, signals, lights etc. The only thing is that it has a rough idle. I touched all four headers quickly after it idled. One was cold, so I'm thinking the carbs need some cleaning.. Could it be something else causing the problem?
Some help would be great! Thank you!
aviator is offline
post #2 of 2 Old 11-05-2013, 6:42 AM
Re: 1977 Honda CB750 Hondamatic
Originally Posted by aviator View Post
Hi all,
Attachment 57838
I would agree that the carburetor is probably blocked.
Off the top of my head the only other problems I can think of that would cause one cylinder to run cold are loose/bad plug lead, loose/bad plug, valve clearance too tight or bent/burnt valves or missing valve adjuster screw, air intake leak, broken ring, holed piston or bent/broken rod. All are easy to check for.
Go Back   Honda Motorcycles - FireBlades.org > Honda Motorcycle Models > Honda Cruisers
Tags
carb work , honda cb750a hondamatic , rough idle
Honda CB750 1971 1977 Swap-Help scott2011 Honda Cruisers 0 10-14-2010 10:57 PM
honda 1981 cb750 custom toddon22 Honda Cruisers 25 09-10-2010 8:43 AM
1981 honda cb750 custom toddon22 General Discussion 0 07-08-2010 5:55 PM
Honda Nighthawk CB750 FOR SALE SpeedCostsMoney For Sale 4 04-27-2007 9:14 AM
Honda Motorcycles 1977 Heavy-Dee General Discussion 18 04-19-2006 12:21 PM
