1984 Honda 700 Magna help..! - Honda Motorcycles - FireBlades.org
Honda Cruisers Discussion of the Honda Rebel, Honda Shadow, and Honda VTX Motorcycles.
post #1 of 4 Old 05-04-2012, 12:15 PM Thread Starter
Working on a 1984 700 Magna. Bike will fire and run for about 2 seconds and die. I have completely gone threw the fuel system: drained fuel from upper and lower tanks, cleaned tanks, replaced fuel lines, replaced fuel filter, bench tested fuel pump, removed and completely disassembled carbs, cleaned, blew out passages, re-set float heights to 7.2mm (.283"), re-build kits, tested floats for cracks, sync all four carbs. Re-installed everything. Bike still has the same issue. I have checked for spark and it looks good, but spark plug is wet with fuel. Seems like when engine fires it imedeitaly stops spark/firing. Do these bikes ever have issues with the ignition control units. Any help that would get me in the right direction to fix this problem would be great. Thanks
FullCircle is offline
post #2 of 4 Old 05-04-2012, 1:08 PM
Re: 1984 Honda 700 Magna help..!
Originally Posted by FullCircle View Post
Working on a 1984 700 Magna. Bike will fire and run for about 2 seconds and die. I have completely gone threw the fuel system: drained fuel from upper and lower tanks, cleaned tanks, replaced fuel lines, replaced fuel filter, bench tested fuel pump, removed and completely disassembled carbs, cleaned, blew out passages, re-set float heights to 7.2mm (.283"), re-build kits, tested floats for cracks, sync all four carbs. Re-installed everything. Bike still has the same issue. I have checked for spark and it looks good, but spark plug is wet with fuel. Seems like when engine fires it imediately stops spark/firing. Do these bikes ever have issues with the ignition control units. Any help that would get me in the right direction to fix this problem would be great. Thanks
Will it continue to run while you spray starter fluid into the intake?
If you clip a timing light on each plug lead you will be able to see if the coil is firing.
When you re-set the float levels were they very far out of spec?
post #3 of 4 Old 05-04-2012, 1:56 PM Thread Starter
2 of the floats were a bit out of spec. I am sure it is not a carb. related problem as fuel is getting into the combustion chamber and when you pull the plugs, they are slightly wet. The carbs are not flooding either.
post #4 of 4 Old 06-25-2012, 5:50 PM Thread Starter
Found the problem...!!! Bad fuel pump relay...!!! Would work intermittently.
Go Back   Honda Motorcycles - FireBlades.org > Honda Motorcycle Models > Honda Cruisers
1984 Honda Magna V30 lindstromjd Honda Cruisers 4 08-18-2010 2:29 PM
1984 Honda Magna VF700 Oapie07 General Discussion 0 09-24-2009 9:50 PM
Honda Magna V30 1984 ellertsm Honda Interceptor / VFR 1 03-31-2009 2:24 PM
My 1984 Honda Magna 700 has a mysterious ailment. Can you think of anything? fishsandwich Honda Tourers 3 09-07-2008 12:35 PM
Can somebody tell me where I can get throttle cables for my Honda Magna V30 1984 ellertsm General Discussion 2 05-22-2008 12:47 PM
