Dynojet QS jumps out of gear 954 - Honda Motorcycles - FireBlades.org
post #1 of 11 Old 08-29-2012, 8:03 AM Thread Starter
Reputation Power: 10
Guys, just wondering if ayone had experience with this. I have a Dynojet Quick shifter fitted and its been working ok. I did a trackday over the weekend and found that it would sometimes shift into a false neutral. Seemed to happen at the same spot on the home finish straight. Does anyone have any ideas? Ive got the oem settings applied.
Any help would be great, thanks
Stanley954 is offline
post #2 of 11 Old 08-29-2012, 8:39 AM
Re: Dynojet QS jumps out of gear 954
if it's coming out of gear It doesnt sound like it's related to the DQS. Could be you're not getting it all the way into gear or it's just not staying engaged in gear. One reason I like the gp shift pattern, the shifts are definite and firm.
If you decide to experiment with the reverse pattern, all you need is a shifter from a VFR. Pull the OE 929 shifter and linkage off and direct swap with the VFR.
medicbaldwin is offline
post #3 of 11 Old 08-29-2012, 9:29 AM Thread Starter
It doesnt happen without the QS fitted mate gear box and clutch are bang on. Might just ake it off to be honest
post #4 of 11 Old 08-29-2012, 12:29 PM
Quoted: 11 Post(s)
Reputation Power: 57
I have had this happen a few times while drag racing and its usually my shifting not being firm enough. When it did happen I was usually due for an oil change.
How much slack do you have in your shifter? I leave very little slack in mine.
SOLD: 03 CBR954
backdoc is offline
post #5 of 11 Old 08-30-2012, 3:08 AM
Reputation Power: 11
Send a message via Yahoo to letsride
CBR1100xx blackbird shifter is also a direct swap.
letsride is offline
post #6 of 11 Old 08-30-2012, 6:30 AM Thread Starter
Doc, ill have a check when I get home and I think your right, im probably not being assertive enough.
post #7 of 11 Old 08-30-2012, 7:18 AM
Reputation Power: 28
Change the oil mate
Surteez is offline
post #8 of 11 Old 08-30-2012, 8:09 AM
Reputation Power: 113
Try adding a few more milliseconds to the engine cut time.
Sky91 is offline
post #9 of 11 Old 08-30-2012, 9:32 AM Thread Starter
Surteez the oil is less than 400 miles old mate went in July Motul 5100 from Hunters
Sky yeah ill try that mate too
post #10 of 11 Old 09-05-2012, 2:59 AM
you get your issue worked out? Could be you dont have the "stroke" of the shifter set bang on with the DQS, so when you go to shift it's limiting the amount of movement you have in the shifter and keeping it from fully engaging.
post #11 of 11 Old 09-05-2012, 7:54 AM Thread Starter
Yes buddy all sorted, I took some of the slack out which has eliminated the problem entirely. Running really nice now
929 Tach jumps a bit at idle jfryjfry Honda FireBlade 7 12-09-2010 12:40 PM
93 Fireblade jumps out of gear when too much throttle coteesh Honda FireBlade 17 09-17-2007 6:02 PM
when it jumps out of gear kiai General Discussion 1 08-20-2007 11:09 AM
Nice bike, ever take it off any sweet jumps? Pete Off-Topic 24 06-22-2006 1:10 AM
FEMA jumps the gun Sunbert Off-Topic 7 02-02-2006 10:58 PM
