929RR RR Relocation? - Honda Motorcycles - FireBlades.org
post #1 of 12 Old 08-31-2012, 7:42 PM Thread Starter
Reputation Power: 8
Anyone on here relocate their RR so that the air can get to it? I've fried another RR in only 2 months. It's either got to have a bad ground somewhere or it's just getting too hot. Any ideas?
Rider4life929RR is offline
post #2 of 12 Old 08-31-2012, 10:29 PM
Re: 929RR RR Relocation?
Buy a Shindengen Mosfet FHO 12AA & mount it in the trunk. I used 2" angle alum. One bolt to the pillion seat bracket needs to be longer & another bolt through the RR to the alum. bracket you'll make keeps the rr in place.
1ccwit is offline
post #3 of 12 Old 08-31-2012, 10:43 PM Thread Starter
Reputation Power: 8
Do you think mounting it in the trunk will make much of a difference over in the tail? I was thinking about mounting it further down the frame under the seat on the left side.. that way it is exposed to the outside. And the air will run over it.
post #4 of 12 Old 09-01-2012, 12:48 AM
There is a third option, OEM Honda regulators and stators are junk.
post #5 of 12 Old 09-01-2012, 1:13 AM
Google the Shindengen you'll see Roadstercycle.com they sell them. They are a little longer than a stock RR so it will not fit where the stock RR is mounted,due to a wire connector. The Mosfet just doesn't get hot...There's a load of post on other sports bike sites about them.
I mounted my in the trunk because it was the easiest place to mount it,wired it with enough wire so I can unbolt it & take it out of the trunk with out disconnecting any wire. It's mounted in almost the same area of the stock location except flat to the inside of the trunk With a 1/2" x 1/2" x 4" alum. angle under the RR. If I had a camera or even a cel Ph. I'd post a pic. You can use the stock wire connector to the stator.
1ccwit is offline
post #6 of 12 Old 09-01-2012, 1:42 AM
That seems to be true Bladeracer...The Mosfet RR has half the problem solved now if we could find good Stators,the more I read I'm thinking the RR's goes first then the Stator fail,no place for the volts/amp's to go. It's hard to believe how cool the Mosfet run.
1ccwit is offline
post #7 of 12 Old 09-01-2012, 8:11 AM Thread Starter
Reputation Power: 8
It wasn't even a oem one the failed this time. I had a ricks Motorsport rr and stator.
I did a lot of reading last night on it. I'll prob break down and get one.
post #8 of 12 Old 09-01-2012, 12:50 PM
Reputation Power: 113
In the mean-time, you can always put a sealed bearing PC fan over it, as they run on 12volts too. Get a Delta if you can - those things push enough air to practically move the bike forward itself
Sky91 is offline
post #9 of 12 Old 09-01-2012, 1:21 PM
You wont go wrong!
1ccwit is offline
post #10 of 12 Old 09-01-2012, 2:05 PM Thread Starter
Reputation Power: 8
If you can get pictures of how u installed yours I'd greatly appreciate it!
post #11 of 12 Old 09-01-2012, 2:43 PM Thread Starter
Reputation Power: 8
And also if I'm looking at it right.. The new harness that plugs into the RR that run's to the battery, does that completely bypass the stock harness plug in and hood straight to the battery?
post #12 of 12 Old 09-01-2012, 3:57 PM Thread Starter
Reputation Power: 8
Already ordered and have a tracking number. Where did you put yours at?
95 blade regulator/rectifier relocation (Sime) DarkStarCBR Honda FireBlade 4 09-06-2018 3:53 AM
Hiss sensor relocation Sky91 General Discussion 0 07-14-2012 6:16 PM
License plate relocation help autoxr37 Honda FireBlade 5 08-14-2011 9:23 AM
Coolant Resivior relocation? Hammer Honda FireBlade 12 09-28-2008 8:59 PM
Arizona Relocation - Advice needed SomeStrangeGuy Off-Topic 21 07-27-2005 5:52 PM
