929 slipping clutch or jumping sprocket? help - Honda Motorcycles - FireBlades.org
post #1 of 5 Old 09-02-2012, 5:32 AM Thread Starter
this is the second time i have asked for tech help and i know someone will be able to help.
i have a 929 and when i really open up the throttle in 1st or 2nd at hight revs it bangs and judders could this be the clutch slipping? its done 42,000 is it a common blade problem?
cheers guys
marcoblade is offline
post #2 of 5 Old 09-02-2012, 4:11 PM
Quoted: 120 Post(s)
Reputation Power: 198
Re: 929 slipping clutch or jumping sprocket? help
Since this is the second time you've asked, than surely you've looked at your chain and rear sprocket? Pull the front sprocket cover and inspect the sprocket?
If you're ready to change oil, or can save your oil in a super-clean container, pull the clutch cover, and inspect the discs and plates. If you don't have a manual, I can help you with the service limit specs of the discs, plates, and springs as I have an online one. Pay VERY close attention when you remove the plates and discs, don't change the order in which they came off. Sometimes the first and/or last clutch-disc is slightly different from the others.
If your rear sprocket looks anything like my last one, then that's your problem for sure!
082.jpg‎
jondog9 is offline
post #3 of 5 Old 09-04-2012, 10:22 AM
I agree a simple visual inspection will go a lot farther then we can tell you. I almost sounds like the chain is too loose(hopping sprocket teeth) assuming everything else looks good
Kratosftw is offline
post #4 of 5 Old 09-20-2012, 10:20 AM Thread Starter
its the second time for different advice.checked spockets and chain tension there all new. must be a gearbox prob as its now jumping out of second gear, anyone else had this problem?
post #5 of 5 Old 09-20-2012, 10:34 AM
Reputation Power: 28
Are u due an oil change?
Surteez is offline
Tags
929 , clutch plates , help! , slipping
954 clutch slipping.... lamron ton Honda FireBlade 8 04-22-2010 12:26 PM
Clutch Slipping dcb2231 Honda FireBlade 3 07-14-2009 6:34 PM
Clutch slipping, Bergerson Honda FireBlade 15 12-10-2008 9:28 PM
slipping clutch Tequila.Sunrise Honda FireBlade 3 10-13-2007 9:25 PM
Clutch Slipping 2001 929rr Honda FireBlade 5 07-29-2003 9:25 AM
