07 cbr1000rr poor idle - Honda Motorcycles - FireBlades.org
post #1 of 29 Old 09-02-2012, 7:35 AM Thread Starter
Hi, my 07 fireblade idles really lumpy when warm, fine on initial startup but gets worse as it warms up, its perfect just off the throttle and flies, if i increase revs via throttle by a couple of hundred this also cures it, its a right pain as it stalls very easy in traffic due to this problem, any ideas???
cheers spillers.
spillers is offline
post #2 of 29 Old 09-02-2012, 8:09 AM
Re: 07 cbr1000rr poor idle
cheers spillers.
What rpm is it idling at?
Have you tried raising the idle?
post #3 of 29 Old 09-02-2012, 8:32 AM Thread Starter
its idling between 900/1200, not sure if you can adjust the idle???
spillers is offline
post #4 of 29 Old 09-02-2012, 8:35 AM
900 is way too low.
Of course you can adjust the idle :-)
There will be an idle adjusting knob somewhere around the throttle bodies, probably around the left side under the main frame.
post #5 of 29 Old 09-02-2012, 10:14 AM
Quoted: 99 Post(s)
Reputation Power: 231
900 is way too low.
The mind is a funny thing
Jazzy's Blog
jazzy is offline
post #6 of 29 Old 09-02-2012, 10:55 AM Thread Starter
I always thought the idle was controlled by the ecu...
spillers is offline
post #7 of 29 Old 09-02-2012, 11:03 AM
Reputation Power: 113
Nope - there's a little adjuster. Looks like this:
Sky91 is offline
post #8 of 29 Old 09-02-2012, 11:23 AM
No, the idle is determined by the amount of air being allowed through the throttle bodies, and that is set mechanically by opening the throttle plates using a screw.
post #9 of 29 Old 09-02-2012, 12:14 PM Thread Starter
thanks but cant find anything like the pic sky91 posted, someone suggested thats only on the 600, as for adjusting the throttle bodies it looks quite complicated....
spillers is offline
post #10 of 29 Old 09-02-2012, 1:25 PM
Then maybe the idle adjuster is missing, but I'd be surprised it idles at all if that were the case.
post #11 of 29 Old 09-02-2012, 1:30 PM
There are only two adjustments on the throttle bodies and neither is difficult.
Synchronising the starter valves, and synchronising the throttle plates using vacuum gauges.
post #12 of 29 Old 09-02-2012, 2:00 PM
Quoted: 120 Post(s)
Reputation Power: 199
You might also have a bad fuel pressure regulator. The symptoms you describe fit.
jondog9 is offline
post #13 of 29 Old 09-02-2012, 7:26 PM
Quoted: 99 Post(s)
My 07 has the idle adjust where Sky91 said. It may have an overflow pipe in front of it or a water pipe. It is definitely there, it's awkward to get to
Jazzy's Blog
jazzy is offline
post #14 of 29 Old 09-03-2012, 4:53 AM Thread Starter
Thanks for all your help, fairings are coming off as I type.....well when ive finished typing....thanks again Spillers
spillers is offline
post #15 of 29 Old 09-03-2012, 5:39 AM
Quoted: 99 Post(s)
Wait !!!!!!!!!!!!!!!!!!!!!!!!
I'll go and take a pic........
Jazzy's Blog
jazzy is offline
07 cbr1000rr poor idle spillers General Discussion 0 09-02-2012 7:24 AM
2005 CBR1000RR Knock at Idle sraney Honda FireBlade 4 05-30-2009 6:14 AM
MY POOR POOR BLADE (Bloody cars) Shark_Blade Wrecked Motorcycle Photos & Stories 19 01-15-2008 3:48 AM
Poor TO. Poor Eagles fans. TAZ Off-Topic 43 02-06-2005 4:16 PM
poor finish on cbr1000rr 954ie Honda FireBlade 30 05-12-2004 3:06 PM
