MIL light does not light - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 09-02-2012, 11:50 PM Thread Starter
My 2004 1000rr runs fine, gets great fuel mileage, none of the LCD display indicators flash, but my MIL light will not light at ignition on to make sure it works.
I have the owners and service manuals from Honda, and both indicate it should light to test it at ignition on, then go out at start up.
Is there a bulb I can check? The service manual covers all the blink codes and troubleshooting, but not what to do if it does not light at all at ignition on.
Thanks for the help.
maxmachz is offline
post #2 of 7 Old 09-03-2012, 7:51 AM
Reputation Power: 113
Re: MIL light does not light
I think this is the first time someone's complained about the MIL light NOT coming on
Could be the LED has worked away from the solder points, or it's not getting a voltage from the ECU. Look at the service manual for the wire colours going into the clocks, and see if there's a voltage on the relevant line.
Sky91 is offline
post #3 of 7 Old 09-03-2012, 8:53 PM Thread Starter
I got my service manual in a pdf format. The diagram showing the wire colors going into the combination meter display is not legible enough to see the wire colors labels, even on full zoom. I can see the wires and the colors, but not the labeling on the plug to see which ones are for the MIL lamp.
It's on page 21-3 if anyone has a paper version and can tell me the colors for the MIL lamp I'd be most appreciative. I'll test them as posted above and see if it's a lamp / display issue or farther up the harness at the plug, or even an ecm problem.
Thanks!
maxmachz is offline
post #4 of 7 Old 09-05-2012, 8:16 PM Thread Starter
Top.....anyone have the service manual that can tell me what color wires / terminal locations for the MIL lamp?
maxmachz is offline
post #5 of 7 Old 09-13-2012, 9:22 PM Thread Starter
MIL lamp was burned out. Thanks to a fellow CBR rider I got a different display, all is good now.
My other one is up for grabs if a handy guy wants to replace the MIL led lamp. 17,200 miles. Not melted. Thanks for all the suggestions and tips!
maxmachz is offline
post #6 of 7 Old 09-14-2012, 4:51 AM
It's actually not that difficult to swap out the LED's if you can hold a soldering iron at all.
Sky91 is offline
post #7 of 7 Old 09-14-2012, 8:05 AM Thread Starter
Do you know what the spec is on that LED?
Thanks
maxmachz is offline
FI light and red light on, PC3 problem? help ezracer Honda FireBlade 18 02-09-2014 4:35 PM
F/S Yoyodyne Carbon Fiber Light Tube w/h light RC51Nash For Sale 1 10-22-2009 10:31 PM
Shift Light / License plate light Gookie Honda Naked Sportbikes 4 02-04-2009 12:27 AM
help my 05 1000rr pgm-fi light & idicator light flashes 3slow 4 fast? impervious Honda FireBlade 9 02-05-2007 1:01 PM
