DRY KIT ON 2001 929 - Honda Motorcycles - FireBlades.org
post #1 of 25 Old 09-04-2012, 7:58 PM Thread Starter
DRY KIT ON 2001 929
TRYING TO INSTALL A DRY KIT ON A 2001 929. I CONNECTED TO THE START BUTTON. AFTER I CRANK THE BIKE AND FLIP MY TOGGLE SWITCH THE HEADLIGHT WILL GO OUT WHEN I PUSH THE START BUTTON. IT WILL GO OUT JUST LIKE IT DOES WHEN YOU START THE BIKE BUT THE SOLENOID DOES CLICK..CAN SOMEONE GIVE ME ANY HELP. WHAT WIRES TO I CONNECT TOO. THANKS
WKMMMP3 is offline
post #2 of 25 Old 09-05-2012, 7:48 AM Thread Starter
Re: DRY KIT ON 2001 929
Has nobody tried it or is it a big secret and nobody is telling..alot of views but no replies
WKMMMP3 is offline
post #3 of 25 Old 09-05-2012, 7:52 AM
Reputation Power: 10
Excuse my n00bness but what is a dry kit?
Stanley954 is offline
post #4 of 25 Old 09-05-2012, 8:23 AM Thread Starter
Its a nitrous kit. There is a wet and there is a dry
WKMMMP3 is offline
post #5 of 25 Old 09-05-2012, 11:21 AM
Reputation Power: 113
Dry Nitrous = injects Nitrous Oxide into the intakes, and relies on the injectors to add the extra fuel required
Wet Nitrous = injects nitrous oxide and fuel into the manifold.
Nitrous oxide engine - Wikipedia, the free encyclopedia
Sky91 is offline
post #6 of 25 Old 09-05-2012, 11:22 AM
Oh, in that case sorry ive no idea :p
post #7 of 25 Old 09-05-2012, 11:30 AM
Quoted: 2 Post(s)
Reputation Power: 15
not really sure what this means "AFTER I CRANK THE BIKE AND FLIP MY TOGGLE SWITCH THE HEADLIGHT WILL GO OUT WHEN I PUSH THE START BUTTON. " Also, not sure what you connected to the start button? basically, you aren't getting responses because it is near impossible to tell what you are asking.
packman5280 is offline
post #8 of 25 Old 09-05-2012, 12:07 PM Thread Starter
ok packman...i have connected my toggle switch to the horn button like i have done on many many hayabusa's. It's a yellow wire with a red stripe. When toggle is in one position the bike starts and when it's switched after the bike has started it sends a signal to your nitrous solenoid and the solenoid with be activated..But the problem is this. When i try to crank the bike the headlight will dim down until the bike starts and when it cranks the light is back on like it should...Here is the kicker...Bike is running and i flip my toggle switch on but when i push the button the light still goes off..
Does anyone on this site have a wire diagram for a 2001 honda cbr 929 or better yet has anyone put one on before and is willing to help...I KNOW IT HAS BEEN DONE.
WKMMMP3 is offline
post #9 of 25 Old 09-05-2012, 2:37 PM
Quoted: 2 Post(s)
i think i see what you mean. you're using the starter button to trigger the nitrous, but when you do that it turns the headlight off. is that correct?
sorry i don't have a diagram.
post #10 of 25 Old 09-05-2012, 7:48 PM Thread Starter
YOU ARE CORRECT PACKMAN
WKMMMP3 is offline
post #11 of 25 Old 09-06-2012, 2:32 AM
just curious, have you thought about running a seperate button to spray your nitrous? Sounds like the start switch idea isnt working out, just yet, and I do not have the wiring insight to help you out?
Have you check with schnitz racing, pingel or mps to see what they have to offer?
medicbaldwin is offline
post #12 of 25 Old 09-06-2012, 3:49 AM
Would the 2000 and 2001 929 be the same wiring?
Firewalker is offline
post #13 of 25 Old 09-06-2012, 9:24 AM Thread Starter
NOT SURE BUT IF YOU HAVE IT I WOULD LOVE TO GET IT SO I CAN CHECK IT OUT.
WKMMMP3 is offline
post #14 of 25 Old 09-06-2012, 9:26 AM Thread Starter
got the kit from MPS and called them but they not that much help..he wasn't really sure either.. i can be done and i will fix it...when i do i will post it for the world to see.
WKMMMP3 is offline
post #15 of 25 Old 09-06-2012, 9:39 AM
Quoted: 159 Post(s)
Reputation Power: 122
So are you connected to the horn button as you say in this post or to the starter button as you say in your first post?
fj1200rj is offline
WANTED CBR929RR ERION ED. AND 2001-2001 GSXR1000R jkobflys Wanted 0 06-26-2012 12:59 AM
How much for 2001 929 ridetolive Honda FireBlade 41 09-14-2010 4:51 PM
2001 929 Help bigin59 Honda FireBlade 1 04-12-2010 10:48 PM
2001 929 help plz drizzle1214 Honda FireBlade 17 01-19-2009 6:12 PM
