Voltage probs! - Honda Motorcycles - FireBlades.org
View Poll Results: Best Bike for an upgrade from 929
cbr 1000 Fireblade 2005 0 0%
GSXR 1000 2005 1 50.00%
R1 2005 0 0%
Aprillia rsv 1 50.00%
Multiple Choice Poll. Voters: 2. You may not vote on this poll
post #1 of 4 Old 09-06-2012, 1:10 PM Thread Starter
Voltage probs!
To anyone who can help or advise! Have tested battery and it is charging properly. Yellow green gauge cluster wire shows 12.89 when ignition on but when engine is running it drops to 8.25 volts, battery is getting 14.05 with engine running! Because of this tacho not working!
Thanks to anyone who can help me with this little beauty.
dzzz01 is offline
post #2 of 4 Old 09-06-2012, 2:35 PM
Reputation Power: 113
Re: Voltage probs!
Check the ground cable cluster behind the gauges (there's a LOT of grounds all going to a block). Look for any signs of corrosion, loose connections etc. Failing that, look at any other connectors between the clocks and the battery checking for loose connections or corrosion.
Sky91 is offline
post #3 of 4 Old 09-06-2012, 3:59 PM
Re: Voltage probs!
It has to be a bad earth on the cluster is my guess.
post #4 of 4 Old 09-06-2012, 5:52 PM Thread Starter
Re: Voltage probs!
Cheers, for that much appreciated. back to work tommorow so will check it out next week and post how I get on! Bikes runnning perfect, just a shame about the rev counter.
Thanks again
Dzzz01
dzzz01 is offline
Tags
help me please
probs with my 929 matt baxter Honda FireBlade 6 03-16-2009 7:58 PM
Speedo probs BMW.Nick Honda FireBlade 1 06-25-2007 8:46 PM
Low Rev Probs ashtanga Honda FireBlade 5 04-02-2007 7:49 PM
954 probs rokitt51 Honda FireBlade 12 03-22-2007 10:53 AM
pc3 usb probs xxshawnxx Honda FireBlade 4 01-21-2006 5:28 PM
