Voltage issues - Honda Motorcycles - FireBlades.org
post #1 of 5 Old 09-06-2012, 10:46 PM Thread Starter
Reputation Power: 10
Voltage issues
I haven't ridden my Blade in a few days and I got on it today and as I was riding I noticed it got all boggy. I noticed I had 150 miles on this tank so I filled up. Didn't make a difference. Notice it was smoking a lot and smelt of unburnt fuel, it seemed if I kept the revs up it was fine. Rode home and checked my voltage. 12.8V at idle. and I noticed when I revved it the lights came on.
I put a known good Suzuki regulator in a few weeks ago (big heatsink so it doesn't overheat)
Is 12.8V at idle normal? I have the bike on a trickle charger. If it runs fine tomorrow I'll know it's a charging issue
GarrettSR5 is offline
post #2 of 5 Old 09-07-2012, 12:11 AM
Reputation Power: 8
Re: Voltage issues
I'm getting 14.2 at idle. What does it do with RPMs? Check the stator output across the phases and report back.
Rider4life929RR is offline
post #3 of 5 Old 09-07-2012, 12:47 AM
Re: Voltage issues
What sort of Blade?
Why did you swap out the regulator?
post #4 of 5 Old 09-07-2012, 1:15 AM
Quoted: 120 Post(s)
Reputation Power: 198
Re: Voltage issues
I believe 12.8V is to low to cause the increase in chemical activity in the battery to give it a full charge.
13.2V is the minimum according to most of Honda's service manuals. Should be around 14V or so at 5000 rpm. with the highbeams on, should not drop below 13.2V or exceed 15V.
jondog9 is offline
post #5 of 5 Old 09-07-2012, 9:13 AM Thread Starter
Re: Voltage issues
It gets weirder. I took the bike to work, battery was charged. 98% of the way to work my oil light comes on. I pull over and check oil. Seems fine. Get to work. Shut the bike off and restart. No more oil light.
losing voltage Dudirtt Honda FireBlade 8 04-03-2012 5:56 PM
Voltage Regulator llhank General Discussion 1 10-08-2011 10:57 PM
93 CBR 900 RR voltage regulator issues CJ Bailey Off-Topic 23 05-12-2010 12:13 AM
Anyone know TPS voltage for F3 WhitsRC Honda CBR 600 3 09-04-2008 7:06 PM
voltage reg Fireblade-RR Honda FireBlade 8 07-12-2004 4:22 AM
