2002 954 spark plug issue - Honda Motorcycles - FireBlades.org
post #1 of 4 Old 09-12-2012, 8:30 PM Thread Starter
anybody out there having an issue with plugs and plug wires going bad? went to the dealer twice for the same problem which they tell me is fouled plugs and bad wires... 2 sets within 500 miles?? something is not right...thanks.
tgoron is offline
post #2 of 4 Old 09-12-2012, 11:39 PM
Quoted: 11 Post(s)
Reputation Power: 57
Re: 2002 954 spark plug issue
Your bike does not have spark plug wires. It has ignition coils on each spark plug. I doubt there is a problem with the coils. Does your bike have a Power Commander or any other mods?
Check your fuel pressure regulator. If its bad it can foul the number 1 & 4 cylinder by dumping excess fuel into these cylinders.
Its best to get a copy of the honda service manual for your bike from the internet and do your own maintenance work. Changing the spark plugs is not hard. You have a prop rod for the gas tank attached to bottom of the front seat. Prop up the tank, remove air box and heat shield then you have easy access to all the spark plugs.
SOLD: 03 CBR954
backdoc is offline
post #3 of 4 Old 09-13-2012, 2:01 AM
As BackDoc says, check your FPR.
post #4 of 4 Old 09-13-2012, 10:16 PM Thread Starter
Thanks! now that you mention it, the fuel smell and consumption seems to be a little off, it smells llike im going through gas like water and im only getting about 20mpg so you could be on to something with the FPR. makes total sense!''\\
thanks!
tgoron is offline
929 Spark Plug Issue gmcdona1 Honda FireBlade 36 07-02-2014 9:54 AM
honda cbr929 no spark at the spark plug engine Help PEXRCV211 New Rider Orientation 0 08-18-2012 9:40 PM
honda cbr929 no spark at the spark plug engine Help PEXRCV211 Honda FireBlade 0 08-18-2012 9:40 PM
2002 919 Spark Plug Removal Orange Krock Honda Naked Sportbikes 4 04-26-2011 10:14 AM
Spark Plug Issue? partyhardryan16 Honda FireBlade 4 01-08-2009 7:58 PM
