954 Exhaust ? - Honda Motorcycles - FireBlades.org
post #1 of 12 Old 09-13-2012, 4:48 PM Thread Starter
Quoted: 29 Post(s)
954 Exhaust ?
I have taken off the rear sets and am in the process of making a replacement bracket to support the exhaust. Without any support bracket the exhaust seems very sturdy. Do you think it would damage anything if I rode without the support for a few days until I make the new one? Thanks, Jay
Exhaust.jpg‎
jdoni is offline
post #2 of 12 Old 09-13-2012, 4:51 PM
Re: 954 Exhaust ?
might put stress on the bracket underneath, at least its not as heavy as standard can.
stevecbr1000 is offline
post #3 of 12 Old 09-13-2012, 9:54 PM
Reputation Power: 56
Re: 954 Exhaust ?
honestly, It would probably be fine. But I wouldn't bet my can on "probably"
52brandon is offline
post #4 of 12 Old 09-13-2012, 11:10 PM
Reputation Power: 12
Re: 954 Exhaust ?
You'll be ok. I rode mine around with no support for months and would take it off anytime without worrying about it breaking or anything
CBR_954_RR is offline
post #5 of 12 Old 09-14-2012, 12:11 AM
Quoted: 120 Post(s)
Reputation Power: 198
Re: 954 Exhaust ?
Did it bend the header at the bottom clamp a little? If it bends, I would think that's where it's likely to.
Different bike, but that happened to me.
jondog9 is offline
post #6 of 12 Old 09-14-2012, 1:38 AM
Re: 954 Exhaust ?
No not at all. The 954 has another mounting point right under the rearset where the exhaust comes out of the fairing. It does a pretty good job of supporting it when theres no hanger
post #7 of 12 Old 09-14-2012, 9:29 AM
Reputation Power: 113
Re: 954 Exhaust ?
Even still, if you're going over bumps the can still has a bit of leverage to go with its weight. You'd be ok in the short term, but I wouldn't want to not have a hanger on there for too long.
Sky91 is offline
post #8 of 12 Old 09-17-2012, 4:11 PM
Re: 954 Exhaust ?
Can you not use a few zip ties to give it some support or even a bit of string?
cheers
Simon
r15suk is offline
post #9 of 12 Old 09-17-2012, 4:48 PM
Re: 954 Exhaust ?
cheers
Simon
If you can't fix it with duct tape, you're not using enough tape
Sky91 is offline
post #10 of 12 Old 09-17-2012, 10:03 PM Thread Starter
Quoted: 29 Post(s)
Re: 954 Exhaust ?
I used some of that Scotch blue painters tape, it peels off easily after it melts.
On a serious note, I took the clamp off the muffler until I make the bracket. Rode for about 100 miles over the weekend and there seems to be no problem. Thanks folks!
jdoni is offline
post #11 of 12 Old 09-28-2012, 6:30 PM Thread Starter
Quoted: 29 Post(s)
Re: 954 Exhaust ?
So... After my feeble attempt to make a replacement exhaust hanger with the limited tools at my disposal it went like this. I just removed the actual footrest portion of the rear set, cut off the mount and sanded it down?
photo.JPG‎
jdoni is offline
post #12 of 12 Old 09-28-2012, 9:33 PM
Re: 954 Exhaust ?
looks damn good to me
'08+ CBR1000RR Two Brothers Exhaust for Stock Exhaust CBRka Swap Section 7 08-09-2012 2:23 AM
What exhaust system is comparible to a BOZ Bros Exhaust? DaDingo8urBaby Honda FireBlade 0 07-23-2012 2:03 AM
FS: 929 Micron Serpent Full Exhaust /// WTB: 929 Stock Exhaust speedaddict Wanted 8 09-16-2011 3:57 AM
Left exhaust tip clean, right exhaust tip black/dusty deckard Honda RC51 4 05-21-2010 4:18 PM
How to add full exhaust to 929? What do you do with the wires for exhaust valves? curt248 General Discussion 11 05-30-2008 9:53 AM
