1000rr no spark - Honda Motorcycles - FireBlades.org
post #1 of 5 Old 09-16-2012, 1:50 PM Thread Starter
1000rr no spark
i recently put a motor in a 07 1000rr everthing is hook up and i have no spark to the plugs. i thought it was the ecu so i purchase a new one an still have the same problem. anyone have any opinions i would appreciate it
repsolking is offline
post #2 of 5 Old 09-16-2012, 2:03 PM
Reputation Power: 28
Re: 1000rr no spark
How old are the Plugs?
Surteez is offline
post #3 of 5 Old 09-16-2012, 2:05 PM
Re: 1000rr no spark
Is the cut off switch on. This kills the sparks if it is off?
Surteez is offline
post #4 of 5 Old 09-16-2012, 2:10 PM
Re: 1000rr no spark
Check the side stand kill switch if your bike has one. It kills the engine so that you don’t start out with the side stand down. If broken or out of adjustment, it would kill the spark. Check for a broken wire at the side stand switch and coupler. Try moving the kill switch by hand. If that doesn’t work then wire a jumper around the switch to bypass it. Check the fuses. How good is the battery? Try a jump start from your car battery. Is the handlebar kill switch on? Check the operation of the ignition switch and all kill switches with a volt ohmmeter. Install new spark plug.
If that doesn't do it, check the wiring harness. Did a wire come unplugged? Are all wires clean and with solid connections? Any abraded or pinched wires? Is the bike in neutral and the neutral light is lit up? If no neutral light, check the neutral switch and neutral switch wire on center casing. If still no spark, get CDI system and coils checked at the dealers shop. You can screw up a CDI unit checking it yourself.
Surteez is offline
post #5 of 5 Old 09-17-2012, 8:36 AM
Re: 1000rr no spark
Does the fuel pump prime?
Is the bank angle sensor connected and mounted correctly?
Why was the engine out?
honda cbr929 no spark at the spark plug engine Help PEXRCV211 New Rider Orientation 0 08-18-2012 9:40 PM
I Really Need Your Help with My 07 1000RR No Spark- basics OK MiniFormulaIndy Honda FireBlade 2 03-18-2010 9:29 AM
04 1000RR No Spark-Detailed diagnostic questions Jackelone General Discussion 7 04-06-2009 9:05 AM
How to change spark plugs on 05 1000rr oneofthosepimps Honda FireBlade 4 07-08-2008 1:26 PM
Spark plug replacement time better on 1000RR Dragger Honda FireBlade 4 06-01-2004 4:08 AM
