2012 1000rr wheels on earlier Blade - Honda Motorcycles - FireBlades.org
post #1 of 9 Old 10-11-2012, 8:47 PM Thread Starter
Quoted: 2 Post(s)
Reputation Power: 15
I may have a deal on a set of 2012 1000rr wheels. For all you who dont know its no longer the 3 spoke design and a semi mesh/12 spoke design. Just curious if honda has changed anything with the CBR wheels post 2003 954rr (the bike its going on.) I know the sizes are the same but idk about the width from bearing to bearing
nyknick1015 is offline
post #2 of 9 Old 10-11-2012, 8:56 PM
Re: 2012 1000rr wheels on earlier Blade
The width across the bearings doesn't matter, make the spacers to suit.
Do measure the width across the discs though as you may have to move the calipers to suit.
post #3 of 9 Old 10-12-2012, 9:14 AM
Quoted: 4 Post(s)
Reputation Power: 77
The forks are further appart on the 08-12 bikes im sure so you would need some custom spacers as BR says. You may have to put the 03 bearing in the wheel perhaps also im not sure and have a play around, you will have to use the front disks off yours as the 08> has diffrent offset etc but stud pattern is the same I think..
http://youtu.be/2ISgxtQXs9o
My 900RR Winter Project
Lambchops is offline
post #4 of 9 Old 10-12-2012, 9:21 AM
I think the discs are a different pattern as well though.
post #5 of 9 Old 10-12-2012, 9:26 AM
Nope, you're right LC, same bolt pattern but 2.5mm more offset. Whether the wheel is narrower or the discs are wider though you will have to measure.
post #6 of 9 Old 10-12-2012, 3:50 PM Thread Starter
Quoted: 2 Post(s)
yeah i figured i would need to use my blades brakes... and thanks... i really hate the 3spoke desgn now so when/if i get my hands on em i will write up a little bit
post #7 of 9 Old 10-12-2012, 4:47 PM
Quoted: 4 Post(s)
Blimey I was right for once BR
Have to agree with you knick, not a fan of the three spoke.. Used to like them and they are easy to clean but multi spoke is the way to go
post #8 of 9 Old 10-12-2012, 5:04 PM
Reputation Power: 34
6 spoke wheels look the nuts in my eyes but why did they have to be hollow on the back of each one? The rear on this bike is orange, believe it or not. Never CBA to clean it.
amorti is offline
post #9 of 9 Old 10-12-2012, 8:46 PM
yeah i figured i would need to use my blades brakes... and thanks... i really hate the 3spoke design now so when/if i get my hands on em i will write up a little bit
When/if you get your hands on them you reckon you'd be able weigh them for us?
will 2012 wheels fit other years? noahb Honda FireBlade 11 06-26-2013 8:20 PM
ANYONE GOT A 2012 BLADE AND WHAT'S IT LIKE 2 DRIVE S1ckb0y Honda FireBlade 16 11-14-2012 10:44 AM
What exhaust should I put on 2012 abs blade S1ckb0y Aftermarket Perfomance Parts Reviews 6 10-09-2012 7:20 AM
RP1 GP On 2012 blade good or bad S1ckb0y Aftermarket Perfomance Parts Reviews 5 10-01-2012 4:43 PM
929 wheels vs 1000rr wheels - weight difference? Junkie Honda FireBlade 11 11-06-2009 12:45 AM
