929 vs 900 Exhaust - Honda Motorcycles - FireBlades.org
post #1 of 14 Old 10-17-2012, 9:53 PM Thread Starter
Reputation Power: 8
929 vs 900 Exhaust
I'm looking at doing a custom exhaust on my 929.. I was looking to eliminate the htev on the 929 exhaust, and possibly stick a voodoo slip on on the end.. But I've been looking at the 900rr exhaust and i think it would be a lot easier to just put on a 900rr header and add the voodoo on the end it. I was just wondering if anyone has tried to bolt up a 900rr header to a 929rr head and if they bolt up.
Rider4life929RR is offline
post #2 of 14 Old 10-17-2012, 9:56 PM
Reputation Power: 12
Re: 929 vs 900 Exhaust
I want to say the OD was different between the two, I just can't remember by how much.
Holder is offline
post #3 of 14 Old 10-17-2012, 9:57 PM Thread Starter
Reputation Power: 8
I could actually see that being possible based on some of the pics I've seen of the 900's.. They look a bit larger than the 929
post #4 of 14 Old 10-18-2012, 7:25 AM
Reputation Power: 34
I read the sumps are different and won't work on the wrong bike.
amorti is offline
post #5 of 14 Old 10-18-2012, 9:25 AM
Reputation Power: 113
This question was asked fairly recently. Short answer is it won't work.
Sky91 is offline
post #6 of 14 Old 10-18-2012, 11:12 AM Thread Starter
Reputation Power: 8
I did a search and came back with nothing that was definite. That's the only reason I asked. What's the long answer?
post #7 of 14 Old 10-18-2012, 12:29 PM
prepair to do some fabrication work for a custom exhaust
Holder is offline
post #8 of 14 Old 10-18-2012, 1:10 PM
Quoted: 2 Post(s)
Reputation Power: 15
the two are not interchangeable without modifications. i know for a FACT that you cannot mix and match cans due to the flange being totally different, and i am 90% sure you cannot bolt a 900 header up to a 929 head or vis versa.
packman5280 is offline
post #9 of 14 Old 10-18-2012, 4:06 PM Thread Starter
Reputation Power: 8
I'm not too worried about the can issue cause I was planning on getting a aftermarket system, then just sticking a voodoo on the end and bringing it out the bottom fairing. Just looking for a way to shorten the exhaust system. I was gonna remove the htev and then bolt the mid pipe directly to the header then cut a chunk out of where its 2 pipes and reweld then attach the voodoo. Currently I have the yoshi 3/4 system and the can has seen better days.
post #10 of 14 Old 10-18-2012, 4:37 PM
Quoted: 2 Post(s)
why not just gut the HTEV, or cut it off and weld a new pipe in, instead of messing with a 900 header? OEM 900 header is one piece fyi, although my 2bros system has a midpipe it is just a slip on that uses springs.
post #11 of 14 Old 10-18-2012, 5:27 PM
Quoted: 4 Post(s)
Reputation Power: 77
I know the 929 headers dont fit on the 900 as the they hit the sump, but the other way around im not sure..
http://youtu.be/2ISgxtQXs9o
My 900RR Winter Project
Lambchops is offline
post #12 of 14 Old 10-18-2012, 8:04 PM Thread Starter
Reputation Power: 8
I'm not too worried about that, but do u know if it will bolt up to the head itself? Like is the spacing the same?
post #13 of 14 Old 10-19-2012, 3:31 AM
Quoted: 4 Post(s)
yes the 929 headers fit the 900rr so must work the other way around.. Theres a thread on here from a couple of months back where someone fitted 929 headers which was fine appart from the pipe fouled the sump. Will try and find the thead for you
post #14 of 14 Old 10-19-2012, 3:33 AM
Quoted: 4 Post(s)
there this one for a start
https://www.fireblades.org/forums/hon...rrw-motor.html
'08+ CBR1000RR Two Brothers Exhaust for Stock Exhaust CBRka Swap Section 7 08-09-2012 1:23 AM
What exhaust system is comparible to a BOZ Bros Exhaust? DaDingo8urBaby Honda FireBlade 0 07-23-2012 1:03 AM
FS: 929 Micron Serpent Full Exhaust /// WTB: 929 Stock Exhaust speedaddict Wanted 8 09-16-2011 2:57 AM
Left exhaust tip clean, right exhaust tip black/dusty deckard Honda RC51 4 05-21-2010 3:18 PM
How to add full exhaust to 929? What do you do with the wires for exhaust valves? curt248 General Discussion 11 05-30-2008 8:53 AM
