Fireblade - Down shifting from 5th to 2nd gear - Page 2 - Honda Motorcycles - FireBlades.org
post #16 of 29 Old 10-31-2012, 8:10 AM
Re: Fireblade - Down shifting from 5th to 2nd gear
im confused at the people saying that you should shift each gear, then how do you back it into corners?
i cant help on the question because i do not know the answer, but on the old blades (98) i can shift as many as i want.
surely someone else here has a blade like yours and can confirm this question.
Monkeycbr is offline
post #17 of 29 Old 10-31-2012, 8:14 AM
Reputation Power: 113
You can steer a car with your feet too - doesn't mean it's the correct course of action.
Sky91 is offline
post #18 of 29 Old 10-31-2012, 8:34 AM
Reputation Power: 290
Think Ive missed something, your having problems changing gears but your worrying about "backing" it into a corner
Irish's Blog Page
Hate this Skin
Assalam-o-Alaikum
setanta is offline
post #19 of 29 Old 10-31-2012, 8:37 AM
its not my thread/problem, i was just comenting on perople saying you should only change one gear at a time, and this just isnt the cas in every circumstance
(The blokes problem is he can only change a couple of gears and then it wont let him shift anymore.)
post #20 of 29 Old 10-31-2012, 10:05 AM
What does gear shifting have to do with backing it into corners?
You can back it into corners without shifting down or even braking.
post #21 of 29 Old 10-31-2012, 10:19 AM
that is true, but the correct method when slowing down for a corner and backing it in, front brake, down two gears clutch out. or for anyone whos ever raced or ridden supermoto.
post #22 of 29 Old 10-31-2012, 10:27 AM
I don't think there is a "correct method", there are different methods that suit different riding styles.
How do you back it into a corner that doesn't allow downshifting or only one downshift?
post #23 of 29 Old 10-31-2012, 10:30 AM
It just occurred to me, are you talking about low-speed cornering like Supermoto and dirt bikes rather than road-racing speeds?
post #24 of 29 Old 10-31-2012, 10:37 AM
no circuit racing, can also be done on the road. if anyone remembers motogp before the electronics. were getting of topic here.
post #25 of 29 Old 10-31-2012, 12:05 PM
But according to you you need to shift down two gears to be able to do it, so how do you do it without changing down at all if this is the "correct" way?
"Backing it in" is nothing to do with downshifting.
post #26 of 29 Old 10-31-2012, 12:11 PM
well you could use the back brake, to slow down the roation of the rear wheel to induce a slide (or use the throttle but this is powersliding)
is that ok mr.
post #27 of 29 Old 10-31-2012, 12:16 PM
is that ok mr.
You don't need to use the rear brake at all, you can put the rear sideways just by moving your body around and steering.
post #28 of 29 Old 10-31-2012, 12:19 PM
not done it that way, cheers,
post #29 of 29 Old 10-31-2012, 12:21 PM
Get yourself off the bike early while braking and the rear will automatically move out to the opposite side to balance the bike, then begin your turn.
Tags
cbr1000rr , downshifting , fireblade , gear , shift
Fireblade 929 stuck in forth gear pinkintheeye Honda FireBlade 4 01-12-2012 2:33 AM
CBR929 1st gear high rpm shifting problem? gsxrkillah Honda FireBlade 4 08-24-2011 1:46 AM
How to replace 2nd gear in your fireblade cbr 929 Hops Honda FireBlade 0 07-06-2010 4:26 PM
Gear Issue on Fireblade RR-T Gazza_London Honda FireBlade 0 05-03-2008 3:08 PM
