954 turn signal issues - Honda Motorcycles - FireBlades.org
post #1 of 36 Old 10-23-2012, 10:53 PM Thread Starter
So my 02 954 has been having a problem with the blinkers. First it was when I turned the left blinker on it would stay on solid. Unless I would turn on the right one then go straight to the left blinker. Now sometime the indicator light on the cluster will blink but the lights do blink most of the time. I have the integrated led tail lights and the led blinkers on the front. Thanks for the help.
johnb07 is offline
post #2 of 36 Old 10-24-2012, 12:50 AM
Reputation Power: 28
Re: 954 turn signal issues
After installing LEDs did you install a new relay?
Surteez is offline
post #3 of 36 Old 10-24-2012, 4:21 AM
Reputation Power: 113
+1 for the relay.
Sky91 is offline
post #4 of 36 Old 10-24-2012, 5:09 AM
Reputation Power: 34
And another
amorti is offline
post #5 of 36 Old 10-24-2012, 6:00 AM
Quoted: 6 Post(s)
Reputation Power: 29
Do you need to fit a new different type of relay or just a new one?
Does this negate the need for load resistors or do you need to fit them as well?
Any UK based riders have the integrated tail light and had it pass an MOT ok?
Im looking at this.. do they have/cause any known problems?
Mollari is offline
post #6 of 36 Old 10-24-2012, 6:16 AM
There are two options to fix the problem - adding power resistors to the circuit, or replacing the turn signal flasher relay.
Surteez is offline
post #7 of 36 Old 10-24-2012, 6:26 AM
An integrated tail light will NOT pass MOT - just have separate signals on the side and you'll be ok.
You need an electronic flasher relay - I used THIS one in my 929 and it's perfect.
Sky91 is offline
post #8 of 36 Old 10-24-2012, 6:28 AM
Surteez is offline
post #9 of 36 Old 10-24-2012, 8:21 AM Thread Starter
So where am I putting a resistor and how
johnb07 is offline
post #10 of 36 Old 10-24-2012, 8:32 AM
It's a lot easier (and WAY neater) to change the relay.
Sky91 is offline
post #11 of 36 Old 10-24-2012, 10:56 AM
Go down the relay route
Surteez is offline
post #12 of 36 Old 10-24-2012, 12:30 PM Thread Starter
What kind of relay do you use
johnb07 is offline
post #13 of 36 Old 10-24-2012, 12:32 PM
An LED flasher relay
Surteez is offline
post #14 of 36 Old 10-24-2012, 12:33 PM
Very cheap and easy to install
Surteez is offline
post #15 of 36 Old 10-24-2012, 1:03 PM Thread Starter
Where would I get one and is it different than a standard relay like for a car
johnb07 is offline
Turn signal issues? Jayson954 Honda FireBlade 3 09-20-2011 9:02 PM
turn signal help adidrick Electronics 8 08-08-2011 11:18 AM
CBR 929rr Turn Signal Issues dlewis23 Honda FireBlade 4 10-27-2010 8:54 AM
Turn Signal Help youngandpayd Electronics 2 05-26-2008 8:17 PM
954 wiring/turn signal issues -Z- Honda FireBlade 3 09-16-2007 2:28 AM
