'97 900RR-V black smoke and won't start... - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 11-13-2012, 10:28 AM Thread Starter
Hi,
I hope someone can help. I serviced my 'blade (oil, filters, plugs) and everything was fine. I fitted an aftermarket exhaust and went for a spin around 15 miles - bike was fine but ran a little rough.
I left the bike for a couple of hours and now it won't start - black smoke comes from the exhaust and sounds like it's going to start if I pull the choke - I've put the original can back on and same problem.
Thanks
VB
Voxblade is offline
post #2 of 7 Old 11-13-2012, 10:59 AM
Re: '97 900RR-V black smoke and won't start...
Originally Posted by Voxblade View Post
Hi,
Thanks
VB
Are all four headers getting hot together?
Does it have a fuel pump or vacuum-operated tap?
post #3 of 7 Old 11-13-2012, 11:36 AM Thread Starter
Hi - I won't be able to check headers until I can get it started and it has a vacuum tap
Voxblade is offline
post #4 of 7 Old 11-13-2012, 2:13 PM
Then pull the vacuum line off and see if fuel comes through it - if it does the diaphram is shot.
post #5 of 7 Old 11-14-2012, 2:06 PM Thread Starter
I'll give it a try and report - thanks!
Voxblade is offline
post #6 of 7 Old 11-17-2012, 1:32 PM
Quoted: 4 Post(s)
Hi, check the airfilter, is it a after market filter?
BLOB748 is offline
post #7 of 7 Old 11-17-2012, 2:09 PM
Reputation Power: 28
It's probably just running a little rich, black smoke is just a little fuel coming out that wasnt burnt I believe.
With this in mind I'd check plugs to see if they're soiled and to so if they're getting spark.
Check battery voltage too. First thing to check when they don't start
Surteez is offline
Black smoke from pipe... need help chris86_CBR Honda FireBlade 10 03-23-2010 8:21 PM
954 and some black smoke BurnsToughFord Honda FireBlade 46 02-26-2010 6:27 AM
BLACK SMOKE???? HELP eliseu General Discussion 4 05-09-2009 3:36 PM
Black smoke Cam954 Honda FireBlade 2 12-17-2006 7:59 PM
black smoke ashkicker Honda FireBlade 10 01-18-2005 7:34 AM
