How to "fix" the 34/35 HTEV MIL without servo motor - Page 3 - Honda Motorcycles - FireBlades.org
 1Likes
post #31 of 40 Old 11-26-2015, 5:03 PM
Reputation Power: 8
Re: How to "fix" the 34/35 HTEV MIL without servo motor
Built mine and installed it today, but the 34 error code is still there...
godoy.rafa is offline
post #32 of 40 Old 11-26-2015, 5:38 PM
Quoted: 47 Post(s)
Reputation Power: 47
ive heard the home built ones work for some and not for others. i bought Honda CBR929RR Exhaust Exup Valve Servo Eliminator Fi Light Removal Vizi Tec | eBay and it works perfectly.
are you sure you cleared the codes after install?
954Kevin is offline
post #33 of 40 Old 11-26-2015, 5:54 PM
Reputation Power: 8
I cleared them. Although it says that there's no need.
50 USD is 200 BRL plus taxes, so no way I'll spend this amount of money to get rid of that stupid light...
post #34 of 40 Old 11-26-2015, 5:58 PM
Quoted: 47 Post(s)
i hear ya. might just try n replace the 2 small resistors. its not uncommon for them to be duds.
954Kevin is offline
post #35 of 40 Old 06-30-2017, 11:31 PM
Quoted: 14 Post(s)
Reputation Power: 3
I have done this successfully on my 2002 954.
The capacitor was ordered on amazon based on the specs in the original post.
The resistors i found in the rummage bin at the local Radio Shack which is going out of business.
The resistors were the same resistance(ohms) as specified in the original post and were 1/4 watt.
The original post specified any wattage but this whole setup definitely worked with the wattage resistors i used.
I will also add that i stuck the resistors and negative side of the capacitor directly into the pins on the empty harness. No cutting or splicing.
I also soldered the two resistors onto slightly different sections of the positive side of the capacitor instead of wiring them together.
The light is off!
speedcrazy1532 is offline
post #36 of 40 Old 08-15-2018, 1:45 PM
Quoted: 5 Post(s)
I have tried this solution with no lock so far.. Error 34 remains.
Now I have seen a picture in this thread. and on this picture a 4.7 Ohm resistor was used..
So now I am wondering..
Could someone confirm the parts for me ?
Regards,
Dragao is offline
post #37 of 40 Old 09-16-2018, 2:39 PM
Quoted: 2 Post(s)
i have made one by myself and buy one,none of them is working,error code 34 still on...now what,no clue?
Can anyone help?
Dojaja is offline
post #38 of 40 Old 09-16-2018, 9:21 PM
Heeza Y Zasch
unslow1's Avatar
Quoted: 385 Post(s)
Reputation Power: 59
Can anyone help?
have you RESET the error codes after doing the modification?
unslow1 is offline
post #39 of 40 Old 09-17-2018, 6:03 AM
Quoted: 2 Post(s)
how i reset this,i have a honda cbr 1000 rr l.2004,i need to do something whit the service conector?
Dojaja is offline
post #40 of 40 Old 09-17-2018, 7:24 AM
Heeza Y Zasch
unslow1's Avatar
Quoted: 385 Post(s)
Follow the procedure(s) outlined in your Honda Service Manual (not the Owner's Manual). If you haven't one, I highly recommend purchasing and/or dowloading, and making yourself as familiar with it as you can... will save you hours of random trouble-shooting and potentially thousands of dollars in labor costs.
...and I believe this thread is intended for 2000-2001 929 and 2002-2003 954 owners. I am not familiar with the 1KRR.
IanDoohan likes this.
unslow1 is offline
2003 954 "faulty egcv and air intake valve servo motor" mariog70 Honda FireBlade 1 05-18-2011 11:44 PM
2010 Honda CBR 1000RR "Factory Exhaust" and "Rear-Set" and "Clutch/Break Levers". whitarnold For Sale 0 01-24-2011 9:19 AM
CBR 929 HTEV Servo Motor Bung stinkoe Honda FireBlade 19 05-27-2008 1:39 PM
Disconnect HTEV Servo Motor Voodoo954 Honda FireBlade 4 04-14-2006 4:41 PM
Disconnecting htev servo motor (954) *mixu* Honda FireBlade 5 06-08-2005 5:09 PM
