Swing arm conversion question - Honda Motorcycles - FireBlades.org
post #1 of 9 Old 12-01-2012, 12:49 PM Thread Starter
I have an 01 929, I just recently found a 954 swingarm. Can I just swap it with the 929 swingarm? Has anyone done this?
ABCDenham26 is offline
post #2 of 9 Old 12-01-2012, 12:54 PM
Re: Swing arm conversion question
Attachment 54318
Lots of people have done this.
As far as I'm aware it bolts straight in.
Not sure if you want to use the 954 shock linkages but you'll soon know when you get it together.
post #3 of 9 Old 12-01-2012, 12:55 PM
Reputation Power: 28
The 954s swingarm is different and more rigid but not entirely sure whether it would fit
Surteez is offline
post #4 of 9 Old 12-01-2012, 12:56 PM
The spools (8mm) fit the 893, 919, 929 and also the 954
Surteez is offline
post #5 of 9 Old 12-01-2012, 12:57 PM
It's also a couple hundred grams lighter.
post #6 of 9 Old 12-01-2012, 12:58 PM
The 929 does not have spool mounts.
post #7 of 9 Old 12-01-2012, 1:24 PM
I'm sure I've seen some with 8mm riv-nuts installed?! Maybe not
Surteez is offline
post #8 of 9 Old 12-01-2012, 1:25 PM
But probably drilled thru the swingarm if not standard
Surteez is offline
post #9 of 9 Old 12-01-2012, 2:39 PM
That's what I did with mine :-)
RRV Swing Arm Conversion Jase_RRV Honda FireBlade 0 06-12-2012 5:49 PM
Single swing arm conversion ALMO General Discussion 2 10-09-2011 4:07 AM
929 swing arm conversion JDC Tools / Garage / Paddock 1 04-24-2010 4:03 PM
vfr swing arm conversion on 01 cbr 929 what do i need ?????help please greg929 Honda FireBlade 4 02-09-2010 9:46 PM
929 - 954 swing arm conversion RickRR Honda FireBlade 3 10-20-2006 6:38 PM
