2007 cbr1000rr flush mount turn signal installation - Honda Motorcycles - FireBlades.org
post #1 of 4 Old 12-01-2012, 5:18 PM Thread Starter
I'm new to the forums so I apologize if there is already a thread. I searched for about 20 min and found nothing. I bought some simple flush mount turn signals and they are supposed to be direct bolt on. But I've never worked on cbrs before. They didn't come with any instructions or anything to hint at how to install them. Any help would be greatly appreciated. Thanks...
JsCBR1000rr is offline
post #2 of 4 Old 12-01-2012, 9:47 PM
Re: 2007 cbr1000rr flush mount turn signal installation
just did mine on my 07, long story short you loosen the side fairings 5or6 snap rivets each side, start with the ones directly behind the front wheel. up in the well behind it, use a flash light and a small screwdriver. there is one nut holding each factory light on once you get in there youll see it. the unplug the factory, put the new ones in there place and wire up the flushmounts on the light side of the connecter. you may need to cut the factory wire plug off your factory lights so your not cutting into your factory wires on the bike side. test and then reassemble
snakeskinner1 is offline
post #3 of 4 Old 12-02-2012, 12:19 AM Thread Starter
Great thanks snake I'll be doing that in the morning! That's gonna save me a couple of bucks. Any other fairly inexpensive mods that can help me out? I already plan on getting a zero gravity wind screen, and I want to do a full akrapovic exhaust including headers, and blade racer mentioned the gearing.
post #4 of 4 Old 12-02-2012, 3:00 PM Thread Starter
I just took the 6 push pins closest to the turn signal out and took a look at it and put it back together. I'm gonna have to take it in and have it done. I'm used to working on my mustang, I don't want to fry any electrical or anything crazy
Tags
flush , installation , turn signal
Flush mount turn signals cmack72 Honda FireBlade 22 12-15-2012 7:40 PM
Flush mount turn signals and more for 929? cannon Honda FireBlade 1 09-20-2010 3:57 PM
Flush mount turn signals 1st954luke General Discussion 7 10-23-2004 6:29 PM
Flush Mount turn signals ie6x Honda FireBlade 17 11-06-2003 1:36 PM
Flush mount turn signals 1st954luke Honda FireBlade 10 06-29-2003 2:20 PM
