2008 FireBlades compression adjuster - Honda Motorcycles - FireBlades.org
post #1 of 1 Old 12-04-2012, 1:45 PM Thread Starter
Hello!
Does anyone have an idea what happened to my front forks compression adjuster? The bike's new for me and i was adjusting (for the first time) compression settings with the front adjuster. I was rotating the screw 45 degrees harder (clockwise) but first I didn't notice that it was already at the hardest setup... well, I rotated it back to the "normal area" where it moves slightly easier and it went OK. Now when I adjust the screw to the hardest setup it moves 45 degrees over the normal end where those two marks match and to the same point where I rotated it first time.
I know that the adjuster is in principle a needle valve and the needle is conical. Is it possible that the needle made the "oil passage" slightly bigger when I tightened the screw too far in, or the oil passage hole formed the needle in new shape, or what? I think the adjuster still works but I'm little confused is it really OK and what happened there.
Thanks already!
Blade08 is offline
Chain adjuster Stimo Aftermarket Perfomance Parts Reviews 10 09-08-2012 3:21 AM
pre-load adjuster not working badmatahfingha Honda FireBlade 5 11-07-2010 6:51 PM
WTB fork pre load adjuster 929/954 1ccwit Wanted 1 11-19-2008 9:50 PM
954 Cam chain adjuster JakeT Honda FireBlade 2 05-11-2006 10:01 AM
rear shock compression adjuster screw Congo Honda FireBlade 4 09-07-2004 2:12 AM
