929rr Spare Key programming - Honda Motorcycles - FireBlades.org
 1Likes
post #1 of 19 Old 12-09-2012, 3:19 PM Thread Starter
Blank transponder key: $20
2 alligator clips, wire, 100 ohm resistor, spade connectors from Jaycar:$14
Scouring this site and others:2 hours
Dudding the hyper-expensive Honda dealers in successfully programming my own key: PRICELESS.
dstap is offline
post #2 of 19 Old 12-10-2012, 8:59 PM
Quoted: 29 Post(s)
Re: 929rr Spare Key programming
Well done! Post up a "How to" article if you feel generous. I know it will be appreciated.
jdoni is offline
post #3 of 19 Old 12-11-2012, 12:39 AM Thread Starter
I have to give credit to many others who have posted HISS key programming tips here and on other forums, esp. "pureguava" on <1000rr_dot_net> forum and "Cronin" from this forum.
However here are the 2000/2001 CBR929rr Aus model instructions:
1) From Jaycar get:
*A set of red and black crocodile/alligator clips (CAT. NO. HM3025)
*1 metre of red wire (CAT. NO. WH3010) and black wire (CAT. NO. WH3011)
* 100k resistor (CAT. NO. RR2822)
* Packet of female spade connector (CAT. NO. PT4822)
* Insulation tape if you dont have any
2) Cut the red wire in the middle and solder the resistor in line. Cover completely with tape
3) Attached croc clips to one end of each of the red and black wires (solder or simply crimp with a vice or good pliers). Cover connection with tape
4) Attach spade connectors to other end of each wire. Crimp or solder.
5) Remove bike riders seat (two hex socket bolts)
6) Remove tank securing bolt
7) Remove two tank bracket bolts
8) Raise tank and wedge something underneath to keep raised.
9) Look for a Red connector that is in a black sheathed line from the top of the clutch cover to the wiring loom that runs parallel with the RHS of the tank. (This is the Ignition Pulse signal wire)
10) Disconnect the red connector. The male end (the two prongs in the connector) has two wires - 1 Yellow and 1 White/Yellow (mine had faded to look mostly white) that run to the loom & onto the ECU
11) I found that I had to squish the female spade connectors a bit in order to get a tight fit on the male connector prongs - a bit of trial and error.
12) Attach the BLACK cable spade to the prong attached to the White/Yellow loom cable and the RED cable spade connector to the prong attached the Yellow loom cable.
13) Make sure your ignition is turned off
13) Attach the red croc clip to the positive + terminal of the battery and the black croc clip to the negative - terminal
14) Put the WORKING key into ignition and turn on
15) The HISS Green LED in tacho face the will come on and stay on
16) Disconnect the red clip from the battery - HISS LED stays on
17) Wait 2 or more seconds - the HISS LED should start flashing four times and repeat this pattern
18) Turn off ignition and remove the WORKING key. The ECU is now in programming mode.
19) Insert your new key (make sure it's one with a transponder in it) and turn on ignition . A pattern of four flashes of the LED means the key has coded! Turn off ignition.
20) You can repeat this process for two more keys (meaning you can have a total of 4 programmed keys).
21) Remove the croc clips and spade connectors and dont forget to re-connect the Ignition Pulse red connector
22) Re-bolt the tank bracket and tank
23) Replace seat and you are done.
This is exactly the process I followed and it worked perfectly first time. Usual disclaimer from me that you do this at your own risk.
If you have Haynes Manual No. 4060 see section 5.4. Explains the above but by using the special ($90!) Honda tool.
Local Honda dealer quoted $250+ to do key programming.....
Hope this helps someone else save a bit of dosh
Joe929 likes this.
dstap is offline
post #4 of 19 Old 12-11-2012, 3:43 AM
Quoted: 29 Post(s)
This doc may help others http://www.maxmekker.com/MC/Manualer...T700V/HISS.pdf
Spaz is offline
post #5 of 19 Old 12-11-2012, 6:42 AM
Nice info...
Hung is offline
post #6 of 19 Old 12-11-2012, 6:47 AM
Reputation Power: 113
250 dollars ?!! They're having a giraffe. Local place to me (Honda dealer) charges 20 minutes labour. It is a fairly easy DIY procedure though.
Sky91 is offline
post #7 of 19 Old 12-11-2012, 1:11 PM
Reputation Power: 10
did i miss something here? When or where are 929 keys chipped? mine looks the same as a honda civic key.
cutsheal5 is offline
post #8 of 19 Old 12-11-2012, 1:50 PM
Quoted: 2 Post(s)
Reputation Power: 15
Yeah, im confused as well, I have a cbr 954 with 3-4 keys and ive just made copies at local hardware stores... maybe just a euro thing
nyknick1015 is offline
post #9 of 19 Old 12-11-2012, 3:48 PM
Quoted: 29 Post(s)
HISS isn't for you lot, only for us living anywhere near scousers.
Spaz is offline
post #10 of 19 Old 12-11-2012, 4:45 PM
I think everywhere except US and Canada has the stupid HISS crap.
post #11 of 19 Old 12-12-2012, 4:55 AM
Even then, it doesn't stop anyone lifting the bike anyway. It's just a pain in the arse for the people who actually own the bike.
Sky91 is offline
post #12 of 19 Old 04-02-2013, 12:54 PM
Sorry for being a dumb fxxk but is this the same procedure as
described here?
MartinSwede is offline
post #13 of 19 Old 04-02-2013, 4:35 PM
described here?
Programming new HISS keys on Honda VFR800 - YouTube
I didn't bother with the video but the procedure is detailed in the OEM and Haynes manuals. Pretty sure I copied it verbatim and posted it here somewhere a few years back.
post #14 of 19 Old 04-02-2013, 4:51 PM
Thanks Bladeracer well the main thing I guess is if the HISS system is setup the same in all Honda bikes and it seems it is. And though itīs a bit of a pain I guess itīs pretty eficient since you always need a key that speeks to the receiver/ECU to be able to start...
post #15 of 19 Old 04-02-2013, 4:59 PM
People that steal bikes don't generally want to start them, in which case the HISS just annoys the legitimate owner.
Hiss programming 600rr Cronin Honda CBR 600 13 11-02-2010 8:28 AM
929RR PC III USB error programming module: 0x002a curbaez Honda FireBlade 3 05-26-2009 8:19 PM
Need programming assistance? evl_twn Off-Topic 4 09-29-2006 11:05 PM
SPEEDTV Programming Changes Red Rider Off-Topic 5 06-24-2003 5:52 PM
SPEEDTV Programming Changes Red Rider Honda FireBlade 3 06-24-2003 5:21 PM
