2000 Honda 929 cbr rr battery draining while bike is running - Honda Motorcycles - FireBlades.org
post #1 of 8 Old 12-09-2012, 5:47 PM Thread Starter
I have a 929 I am experiencing some odd issues with. I am having trouble tracking down the problem. The battery seems to be draining while the bike is running. I know the alternator is doing its job because the bike never cuts off or loses power. But after riding or running for 30 min or so it wont start back up. I got a new battery because i thought the one i had was old but that isn't making a difference. If I pop the clutch it run just fine I just can't figure out where the hell the drain could be coming from. Anyone out there had a similiar problem??
929Bumblebee is offline
post #2 of 8 Old 12-09-2012, 5:50 PM
Re: 2000 Honda 929 cbr rr battery draining while bike is running
How do you know the alternator is working just because the engine runs for thirty minutes? It's just running off the battery. Check your voltage at the stator and across the battery terminals with the engine running, but my bet is bad stator.
post #3 of 8 Old 12-12-2012, 9:00 PM Thread Starter
If it was running off battery it would still show power issues. And even when battery is dead you can pop the clutch and it always runs. Its even run for like 45 min after popping the clutch when the battery died. I was starting to think starter relay might be bad. Any other thoughts?
post #4 of 8 Old 12-12-2012, 9:05 PM
It will run off the battery just fine, I don't have the charging system on my race bike at all, it doesn't need it as long as the battery is charged.
post #5 of 8 Old 12-12-2012, 9:39 PM
Quoted: 2 Post(s)
Reputation Power: 15
Its the regulator/rectifier... this is like the most basic/common problems to check when this happens. Honda R/R's dont really last long til they die out. i would say 4-5 years max til it has to at least be swapped out for most people...
Most people are opposed to it but personally, I bought the cheap Hong Kong Regulators from ebay for like 26 bucks and its been on my 954 for almost 2 years no problem, had a hong kong one on my f2 for 3 years and it still worked when i sold it. OEM r/r will run you almost $150 tho. IMO, if it goes bad ill just buy another one for $26
nyknick1015 is offline
post #6 of 8 Old 12-12-2012, 9:47 PM
It's more likely to be the stator in my experience.
That's on the 929/954/1000RR/F4i.
On the 900RR and earlier 600's it tends to be the regulator
post #7 of 8 Old 12-12-2012, 9:58 PM
Quoted: 2 Post(s)
Bladracer, you probably have more experience but if it was the stator, wouldn't it shut off mid ride and not when you turn the bike off and on? The stator keeps the energy from the engine flowing. Kind of like a car. A good battery will start the car but a bad alternator wont keep the car running.
post #8 of 8 Old 12-12-2012, 10:02 PM
Nope, the main power draw is the starter motor followed by the fuel pump.
It'll run just fine down to around 10.8V before the electrics shut down, that's way too low to power the starter motor.
A good battery will both start the car and keep it running, the alternator has _nothing_ to do with starting or running the engine - it just charges the battery.
Tags
battery , starting problems
Could I get some electrical help? Draining battery eh365038 Electronics 8 04-11-2011 7:03 AM
SP2 Battery continuously running dead Ryan Harington Honda RC51 17 08-19-2010 4:36 PM
why is it Running off the battery? jaewan76 General Discussion 6 06-03-2010 3:52 PM
lights draining battery sloughie Introductions 4 06-28-2009 4:47 AM
Battery Draining psustang89 General Discussion 32 05-05-2009 11:35 AM
