93 blade, electrical poblem. - Honda Motorcycles - FireBlades.org
post #1 of 5 Old 12-10-2012, 10:44 PM Thread Starter
When you switch it on everything works. Except headlights and starter switch. There is a little buzzing from under the dash. When the headlights come on, that's when the starter button works. If not I have to touch the contacts on the main relay and starts right up. But still no headlight when I start it, and it runs fine. Anyone has had this problem or know about it really appreciate the input. Thanks in advance.p.s. I checked the fuses and battery amperage, all fine.
bladejockie is offline
post #2 of 5 Old 12-15-2012, 8:06 AM
Reputation Power: 34
Re: 93 blade, electrical poblem.
Buzzing noise usually refers to a relay that's no the fritz. Can you localise it? Does the US model have always on light which cut out with the starter button? If so that would require a relay which may be your culprit.
Sorry for the vague guesses, I never worked on a US bike nor on a 93, but consider this a free BTT.
amorti is offline
post #3 of 5 Old 12-15-2012, 1:39 PM Thread Starter
Yeah and I think it just went out all together, stopped buzzing, no headlights, won't start. I know it's under the gauges, that's where the buzzing was. Gonna go figure it out today. Hopefully it's and easy one. Mine has the light always on and cut out with the starter. Gonna start there.
post #4 of 5 Old 12-15-2012, 8:04 PM
Could well be your culprit mate! "Should" be that you can use one of the other relays to test it.
amorti is offline
post #5 of 5 Old 12-15-2012, 11:24 PM Thread Starter
Ok man now i feel like an idiot. You know when things mess up and you just start really overthinking the problem? Found a fuse panel that i didnt know about, sure enough the bottom fuse says Head/Ign. Imagine that. Replaced the fuse, everythings good. I always do that overthinking stuff.
electrical garrystevens Honda FireBlade 1 07-11-2011 11:45 PM
Electrical Help?!?! ultrawillman General Discussion 2 05-13-2011 6:30 PM
would a top yoke from 1996 blade fit onto my 2001 929 blade???? ahoulding Tools / Garage / Paddock 4 10-31-2010 4:44 PM
KTM 690 ELECTRICAL HELP race d Supermoto 0 09-09-2010 3:42 PM
Electrical help TomMac General Discussion 2 08-30-2007 1:02 PM
