Just bought a 929, specs of oil coming from exhaust before warmed up - Honda Motorcycles - FireBlades.org
post #1 of 12 Old 12-13-2012, 6:34 PM Thread Starter
Reputation Power: 11
Hey I just bought a 01 929 with 20k on the clock. The guy drove it to my house so when it got to me it was warm and it ran fine. The next morning it was probably 40 degrees outside and I started it up. White smoke was coming out of the exhaust, but I think it was more of a condensation vapor and not smoke. It did not smell and evaporated quickly. The white smoke went away after a minute or two when the bike warmed up, but while warming up when I put my hand behind the exhaust to smell the smoke I saw specs about the size of a pencil tip of oil splatter on my hand. Not a lot but enough to notice. This also gradually lessened until it was completely gone when the bike warmed up. Is this something I should be concerned about?
I am going to change the oil this weekend, along with coolant flush and brake fluid. If it matters the oil is over the seeing glass. My buddy says he thinks it should be halfway up the glass so it might be overfilled. Also my radiator is full of green coolant that looks normal, but the coolant expansion tank is bone dry from what I can see without a flashlight. The bike also has headers and exhaust if that matters.
01 929
socci is offline
post #2 of 12 Old 12-13-2012, 7:18 PM
Re: Just bought a 929, specs of oil coming from exhaust before warmed up
Are you sure it's not just moisture and carbon deposits?
The reservoir is only required if the engine runs hot enough to spit coolant out of the cooling system. If it concerns you then put some coolant in it.
post #3 of 12 Old 12-13-2012, 7:54 PM Thread Starter
Possibly, but the "oil spots" were liquid. Not saying the carbon deposits mixed with the moisture cant give that appearance, but it was unsettling to see the day after I bought the bike.
01 929
socci is offline
post #4 of 12 Old 12-13-2012, 8:25 PM
Have a look at what comes out of the tail pipe of your car when you start it up cold.
post #5 of 12 Old 12-13-2012, 8:39 PM
Doubt you have any real! Guess you could pull the plugs and inspect, or get a compression or leak down test, if the problem gets worse.
drae150 is offline
post #6 of 12 Old 12-13-2012, 8:41 PM Thread Starter
Lol I guess I will give that a try
True, I am in the process of replacing everything I can before spring so that makes sense.
01 929
socci is offline
post #7 of 12 Old 12-13-2012, 8:51 PM
Quoted: 29 Post(s)
Change the oil and get it to the proper level (between the hash marks in the window). Have someone else hold it level so you get an accurate reading. Check the air filter and vacuum system for signs of oil also
Then as BR said double check that the residue coming from the tailpipe is indeed oil and not just carbon water. They look similar, but different texture. G/L, Jay
jdoni is offline
post #8 of 12 Old 12-13-2012, 9:32 PM
Reputation Power: 55
52brandon is offline
post #9 of 12 Old 12-13-2012, 11:24 PM
Originally Posted by 52brandon View Post
Not a particular fan of Eddie but that is a great movie :-)
post #10 of 12 Old 12-14-2012, 11:56 AM
Quoted: 29 Post(s)
You should see the wall behind my wifes 200k mile Volvo with leaking valve seals, still runs like a dream though
Spaz is offline
post #11 of 12 Old 12-14-2012, 2:41 PM
Reputation Power: 25
I wouldn't be too worried. Keep checking the oil level, other than that.. I really think it's condensation if it stops when warm.
eu4ic1000 is offline
post #12 of 12 Old 12-14-2012, 5:00 PM
Quoted: 3 Post(s)
Reputation Power: 10
Send a message via Yahoo to cbrosu
don't worry
my does the same thing, last time i start it it was 50 F outside . from what i understand if you have a oil/coolant burning issue it will blow smoke all the time no matter if warm or cold
cbrosu is offline
flame coming out of the exhaust gaman Honda FireBlade 7 06-06-2012 11:10 AM
What's coming out of my exhaust? 12thPlanetRider General Discussion 2 06-03-2011 2:18 AM
Raw gas coming through exhaust scaredem23 Honda FireBlade 8 07-16-2010 5:29 AM
Exhaust bolt torque specs Kylix9 Honda FireBlade 0 08-14-2008 8:59 PM
exhaust torque specs... kirnox Honda FireBlade 4 03-13-2005 12:48 PM
