upgrade new suspensions - Honda Motorcycles - FireBlades.org
post #1 of 4 Old 12-14-2012, 12:08 PM Thread Starter
Reputation Power: 9
Hey 97 cbr900rrv. I am wanting to know what front springs to use and oil u guy prefer I'm 6ft 3. 245lbs I have the rear set good but at my Weight I'm loosing travel. So shop tech recommended I swich springs in front and add thicker oil any ideas? Thanks. Oh I thank u for the hekp with the rear tail plastics so far they are same bolt locations so I just need to get rear fenders lft an rite. Then find atail light under body kit witg turn sigs in the tail/brake I seen one on ebay so ill see but that and a rear hugger would really compleat the look.
ragecage8966 is offline
post #2 of 4 Old 12-14-2012, 12:18 PM
Re: upgrade new suspensions
I would not increase the oil weight above 10W.
By "losing travel" you mean the forks are bottoming out under brakes?
Have you tried reducing the air gap by putting some more oil in?
post #3 of 4 Old 12-15-2012, 7:59 AM
Reputation Power: 34
Can you still use the preload adjusters to get satisfactory static and rider sag? If not you may need stiffer springs for optimum performance, as you are relatively heavy compared to the typical rider and anyway those springs are old and may have fatigued / sagged a bit by now.
Any susp tech will be able to tell you what fork weight to get, at your weight I guess (total guess) something like a 0.95 to 1.05kg/m linear spring would see you right, especially if you don't take passengers.
Use whatever oil the spring manufacturer recommends, change the springs and you'll need different oil than stock in many cases.
amorti is offline
post #4 of 4 Old 12-15-2012, 7:12 PM Thread Starter
Reputation Power: 9
thanks bladracer, i'll try that first, if that dont work i'll go to installing new springs, are all the fork oils at 10w pretty much like oils, find one that works for you and go from there,>?
To Upgrade or Not to Upgrade lankyruss General Discussion 24 11-30-2010 1:01 AM
Upgrade 101... wander81 General Discussion 2 10-19-2007 2:00 PM
Thermosman suspensions ND4SPD Vendor / Seller / Dealer Reviews 27 06-08-2006 5:30 AM
Suspensions Critz Off-Topic 29 07-21-2003 2:25 PM
Suspensions Setting Heavy-Dee Honda FireBlade 2 06-28-2003 10:47 AM
