Electrical Help CBR 1000RR!!! - Honda Motorcycles - FireBlades.org
post #1 of 3 Old 12-15-2012, 8:11 PM Thread Starter
I have an 04 CBR 1000RR. The last few days the bike had problem starting up. So I thought it was the battery. So before I'm able to get the battery I was getting jumped by a car while on (I know bad idea) . So yesterday I got a jumped from a co worker it blew out my lights and about 7 miles into the ride home was hearing a hiss from the battery, smelling battery scid and then my bike cut off. I put in a new battery and the bike just turns over, won't start and the red light (which II'm guessing it's for power) flashes a couple of times and also this "FI" on the dash far right. I checked all the fuse and all are good. Could this be that my stator, rectifier and battery went to crap. As well as my head lights. Could of jumping the bike cuased other parts to blow with out blowing the fuse?
Rurouni is offline
post #2 of 3 Old 12-15-2012, 8:56 PM
Re: Electrical Help CBR 1000RR!!!
If the car engine was running then it's likely you fried the battery at least.
If the engine wasn't running then it won't have done any harm.
post #3 of 3 Old 12-16-2012, 4:11 AM
Couple of things to check. The headlights are turned on by a relay that is located right next to the fuse box. Remove each relay one by one and test these relays. I know that two of them are for the ignition/fuel injection system and i know one of the others is for headlights. Use a battery on a test bench and pic the relay. Apply 12vdc to the two like positioned spades and the other set should change from open to closed. If one is bad replace it and i bet the bike starts. The battery issue could be the regulator/rectitfier. It is just back from the fuse box. Get the bike started and unplug the two wire red/black harness. Meter the output of the r/r and make sure it isnt overcharging the battery. Thats most likely the hissing you hear. its overcharging the battery, the contents are literally boiling from the heat. 13.8 vdc is what you should get. If it is much over 14 thats too much. each leg of the stator should be about 14vac to ground. they should all be within 10% of each others voltage when reading them to a ground reference. Hope this helps!
Between the ditches....shiny side up. Two things keep me safe, my XD and my riding jacket.
Tims04fireblade is offline
05 1000rr starting/electrical issues lilr3dblade Honda FireBlade 12 07-24-2012 5:38 AM
05 1000rr electrical glitch, help me please :) Minzfast Honda FireBlade 4 02-11-2011 4:30 PM
'04 1000RR Ignition/Electrical Prob? Yare1000RR Honda FireBlade 6 10-10-2010 2:24 AM
06 1000rr electrical problems ? i think swannee08 Honda FireBlade 1 05-09-2010 12:22 AM
2007 CBR 1000RR Electrical Problem Help cbr1k2007 Electronics 0 08-31-2009 4:44 PM
